Show your support and Donate!
Results 1 to 8 of 8
Thread: Brakes feel spongy, need to pump them
  1. #1
    Registered Member YelPro03's Avatar
    2015 Mazda 3s Touring
    Join Date
    Feb 2004
    Location
    Piscataway, NJ
    Posts
    422
    I just got new brake pads installed and rotors machined. The guy at the shop says the brakes will feel a bit spongy or soft at first until the new pads wear in. When I first hit the brakes the pedal nearly goes to the floor before it will stop. But if I hit the brake pedal, let up, and hit it again it will feel normal. It's been a week now and it is still like that. Is that normal or could it be something else (air in the brake lines, master brake cylinder going, etc.)?
    2015 Mazda 3s Touring Hatchback 6-speed manual
    2014 Mercedes-Benz CLA250
  2. #2
    Woohoo! clicknext's Avatar
    2006 Tungsten Grey Mazda6 GT I4
    Join Date
    Jun 2005
    Location
    Canadia
    Posts
    1,337
    This happened when I changed my brake pads. If you don't see any brake fluid leaking then air probably got into the brake lines, and the brake fluid needs to be bled or flushed. When I took it in, the tech said that this is normal when you're changing pads/rotors, and that it's standard for them to do a brake bleed whenever they do a change.
    I think it's probably because when you step on the pedal the first time, the air compresses, and then when you go to step on it again immediately, the air hasn't expanded again so it feels tighter. But if you let off and drive for a while, the air will expand again.
  3. #3
    Join Date
    Feb 2004
    Location
    Piscataway, NJ
    Posts
    422
    Quote Originally Posted by clicknext View Post
    Yes, that's exactly what happens. It must be air in the lines. Thanks. Oh, and I have a yellow P5 also. Well, actually it's my wife's.
  4. #4
    Retired FS King ForceFed's Avatar
    Trailblazer SS AWD ....Still a Mazda Junkie Though.
    Join Date
    Mar 2003
    Location
    Dayton,OH
    Posts
    9,399
    Yup..Sounds likeit needs bled...which they should have done.
    Definately not normal..It should never feel like that..not even on break in or "Bedding" as it called.
    "First they ignore you, then they laugh at you, then they fight you, then you win."
    Mohandas K. Gandhi
    (p5silver)
  5. #5
    Join Date
    Jun 2005
    Location
    Canadia
    Posts
    1,337
    Quote Originally Posted by ForceFed View Post
    yeah, forcefed is right, they should have done it in the first place so you really shouldn't have to pay extra to get it done.
  6. #6
    P5 OG Nomad's Avatar
    Donated: $5
    Join Date
    Oct 2002
    Location
    SoCal
    Posts
    1,010
    Don;t ever go to that hack mechanic again, except to tell him he's an idiot and that he almost killed you because he didn't bother bleeding the lines.
    He's lazy and figured you'd go away.
    Bleed your lines well and replace with good fluid and you'll be really happy.
    Me: '02 Black P5 - Eibach Pro-Kit, Tokico Blues, Added Leather, RacingBeat exhaust, 17x7 10-spokes, Short shifter, Mz6 rear wiper, tint + more.
    Wife: '06 Mazda3 Hatch Grand Touring, Titanium Grey
    For fun: '91 E30 BMW under construction
    http://www.cardomain.com/id/nomadsmx5
  7. #7
    Join Date
    Feb 2004
    Location
    Piscataway, NJ
    Posts
    422
    Thanks for all your inputs. I called them and I'm bringing the car back tonight. They're usually pretty good as I've been going to them for well over 15 years. Maybe they got a new mechanic or something. Hopefully they'll fix it for free.
  8. #8
    Join Date
    Feb 2004
    Location
    Piscataway, NJ
    Posts
    422
    It most certainly was air in the brake lines. Now it is fixed. Thanks for everyone's input and help.
Similar Threads
  1. GP Light Weight Protege pulleys
    By Brach in forum Completed Transactions
    Last Post: 08-21-2009, 05:37 PM
  2. loads of camdriven fuel pump info!
    By mrlilguy157 in forum Mazda6 Engine & Transmission
    Last Post: 11-04-2007, 04:55 PM
  3. 33k Kms and my brakes look like crap!!! (lots of pics)
    By gothmobile in forum Protege5 Lounge
    Last Post: 09-06-2005, 07:35 PM
  4. Big brakes and idle problems
    By bill harvey in forum MSP Lounge
    Last Post: 06-20-2004, 11:17 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
