sureshot324
I've got a couple more newb questions. Can someone describe how the wiring would typically be run for a sub/amp in the trunk of an 03 Protege?
Would the RCA cables come out from under the dash, run under the floor mats, under the rear seats and into the trunk? Does this require the removal of the rear seats?
For the power wiring to the battery, what's the best place to get it through the firewall? Is a fuse required and if so how is installed and where does it go?
