Push down the clip on the right side hard, pull the block on the left hard.
the clip also has two sets of wire running from it. one to the o2 sensor and one to the fuse box. am i going to have to cut the wires to separate the two?
hmm im not sure either. came like that when it was bought. better do some research first then.I dont know what kind of hack job that is....those wires should be running all together to the o2 sensor....even if you use the non fouler trick it's still not going to work...you need to correct those wires first.
