when i did mine the bracket fit just fine
yup mine is just a little off... i think some washers would do the trick but then the mounting bolts are kinda short.
Just to update this thread, It turns out the holes in the brace on the part connected to the block are oval, a.k.a. adjustable. I loosened the nuts, moved it up slightly, and it fit no problem.
So there you go.
