Visit TeamMFactory.com for the best Mazda transmission components!
Page 1 of 9 123 ... LastLast
Results 1 to 15 of 123
Thread: SRI vs CAI on the DYNO!
  1. #1
    Registered Member driver311's Avatar
    08 speed 3
    Join Date
    Sep 2007
    Location
    idaho
    Posts
    804
    Got bored the other day so I went to the dyno to test my sri vs. my cai. Take it for what you will. Here are my thoughts. I like the sri better. Plain and simple I believe its safer, looks better, and has the potential to make more topend hp. The dyno did not show that. The intake tested was a fugita cai. I tested it full length and then cut it right after the fugita emblem and tested it again. Test car was a mine with the following mods. Second cat removal, one resonator and muffler removed, fugita intake, turbosmart bc 13-15psi. I also have a mapclamp on the car and is clamped at 3.5 volts. I think thats right around 15psi. Here is the graph. I hope this help will put the debate to rest. Which is better cai or sri. LOL
    I will be testing the ets tmic and pg fuel pump hopefully tonight. Wish me luck!!!!!!!
    08 Speed3. Atp 3071r 18psi 396whp 380ftlbs.
  2. #2
    Adam Carolla Fan SharkDiver's Avatar
    Speed3
    Join Date
    Mar 2007
    Location
    NW Indiana
    Posts
    1,154
    To be honest it really dont prove anything.You could have not changed anything after the first pull and still get more or less hp,Thats just how dynos work.Just like when someone takes there car to a dyno and they do 3 pulls all 3 will be different and nothing was changed.The red line in the graph seems to be more of a smoother increase then the jagged blue line.I wonder if that means anything.
    car sold Pauter rods,Cp pistons 9.5:1 bored .020,Re-Worked KO4,rear MM,TWM shifter bushings,Cobb SRI,Cobbs AP,Cobb FMIC,Cobb turbo inlet,DNP ceramic coated exhaust mani,TurboXS Dp/racepipe with high flow cat,muffler & 1 resonator removed,1 step colder plugs,Oil CC,Forge BPV,CDFP internals,Debadged, Blacked out reflector tint,Shaved Side Moldings,20% window tint,Clear Factory Bra,ProSport boost gauge,royal P tranny/PP motor oil and more
  3. #3
    Zum Zum Ya? ZOOMit's Avatar
    09 Mazda 6 / 10 Mazda CX-9
    Join Date
    Dec 2007
    Location
    Daphne, AL
    Posts
    483
    I was thinking abt getting a CAI but the fear of sucking in water makes me lean towards a SRI, but I hate the idea of pulling in hot air from the engine. Although I could just make up a heat shield and fix that somewhat.
    -Jeremy
  4. #4
    08 speed 3
    Join Date
    Sep 2007
    Location
    idaho
    Posts
    804
    I forgot to mention that the redline is sri and the blue line is cai. Like I said take it for what you will. I didnt have the smoothing up high and this was in 4th gear so the line will be more accurate. Not a smoothed out version of what the car is actually doing.
    Ps. Shark you dont have to tell me how a dyno works I live on them. My friend owns it and to be honest your statement is false. This dyno has been very consistant for me and all the cars and quads I have dynoed on it. Yes maybe a 1-3whp difference but otherwise pretty close. The only thing Im trying to portray with this post is that there isnt that much of a difference so why say one is better than the other. CAI IS OVER RATED!!!!!!!!!!!!!!!!!!!!!!!!!! Just put something on there that flows good and be done with it. Thats the idea.
  5. #5
    08 speed 3
    Join Date
    Sep 2007
    Location
    idaho
    Posts
    804
    Quote Originally Posted by ZOOMit View Post
    Dude when your driving the engine bay is full of cool air and not to mention this is a turbo car people. No matter what the ari is going through a hot ass turbo so thats why we have an intercooler. YOu woould be wasting your time and money trying to build some form of shield. If you dont believe me go make some wot pulls and then pull over and feel your intercooler and intake tube. It will be cool to the touch I guarantee.
  6. #6
    Speed3
    Join Date
    Mar 2007
    Location
    NW Indiana
    Posts
    1,154
    Quote Originally Posted by driver311 View Post
    How is my statement false?Do you want me to think that YOUR dyno shows the same numbers for you evertime you dyno it unless you change something?Also Im not tring to say 1 is better then the other because I dont know.
  7. #7
    08 speed 3
    Join Date
    Sep 2007
    Location
    idaho
    Posts
    804
    Quote Originally Posted by SharkDiver View Post
    Im not debating different days show different numbers. Thats a known fact. But I can do back to back to back dyno runs with proper cooling on the same day and they are always within a few whp. Thats my point. Thats why i say your statement is false. Im not comparing days to day here bud. This was within 20min. of each other. Dynos should be used as tuning tools and as long as you are using them on the same day under the same conditions they are very accurate.
    Ps. part of the reason you see alot of peoples dyno runs inconsistant is because of the stock tmic. Heak soaks very easy on the dyno. Most dyno operators dont take that into account for the first few runs. So if you keep a fan on it the whole time your runs will be alot more consistant. Aftermarket intercooler makes for a much more consistant day. Hope this sheds some light
  8. #8
    Registered Member Hirudin's Avatar
    '07 Mazda Mazdaspeed3 - Silver, GT
    Join Date
    Sep 2007
    Location
    Albuquerque, New Mexico
    Posts
    428
    SRI is better... they're cheaper.
  9. #9
    08 speed 3
    Join Date
    Sep 2007
    Location
    idaho
    Posts
    804
    Very true. I like cheap. LOL
  10. #10
    Registered Member Igve2shtz's Avatar
    2006 Speed6
    Join Date
    Apr 2007
    Location
    Ocean County, NJ
    Posts
    552
    Nice post. I always wanted to see an un-biased approach to this question.
    2006 MS6 Velocity Red Mica
    [installed] Cobb AccessPort OTS Stg 1 - Cobb TIP - CP-E Nano - ETS 3.25" TMIC - Forge BPV - CP-E Motor Mount - Denso ITV22 - Corksport 3" Resonated Test Pipe - Corksport CBE - Mazda Turbo TSB - BC Coilovers - Prosport Premium Boost Gauge - Vent Pod - Dashhawk - Audiolink iPod Adapter - Superbrightleds Parking Lights - Lumenitics Ultra White Fog Lights - Stock Wheels - 215/45/18 Pirelli P-Zero All Seasons - EBC RedStuff Brake Pads
    [Bonus parts] CP-E FMIC - HKS BOV - Protege Garage TIP - Work Emotion CR-KAI 18x7.5 Gunmetal
  11. #11
    Mr. Registered User 2ManyCars's Avatar
    2008 MS3 GT (SOLD)
    Join Date
    Nov 2007
    Location
    Poway, CA
    Posts
    309
    CAI is better 'cause it's what I spent my money on and it looks cooler even if the air is not cooler...
  12. #12
    Registered Member palerider's Avatar
    mazdaspeed3 black mica
    Join Date
    Mar 2007
    Location
    Greensboro, NC
    Posts
    617
    Everybody knows the longer your pipe is, the more it'll scream. I say stick that sucker right thru to the ground!!
    2007BlackMica MS3...its had a little work done on it
  13. #13
    Banned
    Rust Bucket
    Join Date
    Oct 2007
    Location
    Linden/Charlotte NC
    Posts
    8,565
    so the cai makes more horses and the sri makes more torque, really there about equal just depends on what ur lookin for
  14. #14
    Registered Member
    Join Date
    Jul 2007
    Location
    Calgary, AB
    Posts
    129
    hmm, this post makes the cobb sri look like a very good option for me. I wonder if mazda will get pissy about warranty 'cause it's not a mazdaspeed part? Also cobb should make a dry-filter option for the sri.
    07 MS3, cosmic blue, bone stock (for now?)
  15. #15
    mazdaspeed 3
    mazdaspeed 3
    Join Date
    Apr 2006
    Location
    Round Rock, tx
    Posts
    462
    maybe minor diff. between torque and hp, but basically they are getting the same results just the sri cost less and looks better, so basically you are paying more for cai to gain nothing more than the sri
    Current mods:Injen cold air intake, custom 3" turbo back exhaust, Greddy full auto turbo timer, Forge blow-off valve, faze boost/vaccum gauge, shaved emblems, blacked out "M" emblems, Two pioneer 12" subs w/ 1000watt pioneer amp, custom enclosed box.
    Near future mods: Front mount intercooler kit, engine management, water/meth. injection....
Similar Threads
  1. Dyno results: 2007 MS3 w CPE TBE & MS CAI (dynojet)
    By Unoriginaluser in forum MS3 Lounge
    Last Post: 12-02-2007, 12:27 PM
  2. WTB: CAI or SRI for Manual P5
    By D-Cash24 in forum Completed Transactions
    Last Post: 09-26-2007, 09:50 PM
  3. Anyone Have a Dyno Chart of Injen CAI?
    By the_jaf in forum Protege Performance
    Last Post: 06-12-2007, 08:55 PM
  4. CAI vs SRI temps findings
    By igdrasil in forum Protege Performance
    Last Post: 10-01-2004, 04:05 AM
  5. Convert Injen CAI into an SRI?
    By Bhamsan in forum MSP Archives
    Last Post: 11-16-2003, 08:22 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
