Rear brake replacement?
Rimbo
Is there something special you need to do to push the piston in on the rear brake assembly? I tried a c-clamp but don't want to force it. I allready replaced the front pads and they went in with no problem.
at the back of the caliper,remove the 14mm bolt,and then in the hole,there s a alen key 6mm that you unscrew to pull the piston back in...
you use the same bolt to adjust the rear brakes properly.....
x2 Be sure to tighten it hand tight then back off 1/4 turn. After that make sure everything spins freely. If so, put it all back together and you are good to go.
