Upgrade your Mazda with High Quality Parts at Great Prices from James Barone Racing!
Page 1 of 2 12 LastLast
Results 1 to 15 of 23
Thread: A Discussion For Proper Lifting and Jack Placement...
  1. #1
    Registered Member
    Protege5
    Join Date
    Jun 2006
    Location
    Denver, CO
    Posts
    75
    Everyone seems to have their preferred method and everyone thinks they know whats what, but after searching the countless threads on the subject, it has become clear to me that there is no consensus regarding how to properly jack a Protege5. There is also some debate regarding where to place jack stands as well. Searching this topic is lengthy and difficult, so I was hoping this thread could turn into a sort of forum reference on the subject. Maybe even a sticky in the proper forum.
    First of all, the Protege/Protege5 is a unibody car, so you can't just jack it up wherever you feel like it and throw jackstands under the big solid frame because there is none. Jacking in the wrong place can cause local damage to the vehicle and in a bad scenario, tweaking of the subframes of the car which would cause it to be underivable, not to mention unsafe.
    The owner's manual is of little help, as it only points out the locations of the 4 lift points along the frame rails. This is fine for jacking up one corner at a time, but it does nothing to divuldge where the jack stands should be placed. For instance, lifting the car at the driver's side front jack point leaves you no room to place a jack stand along the frame rail because the only strengthened point along the rail is already in use by the jack.
    Below are some snippets from past threads and my interpretation of each:
    I hardly ever lifted it with a jack, it's so much easier with a lift.
    This is not helpful information at all. The discussion was about using a jack. If we all had access to a floor lift, threads such as this would not be necessary.
    On todays cars your best bet is to jack it up one side at a time then set it on jackstands.
    Okay, jacking it up one side at a time is certainly a possibility, but said user failed to discuss where the jack stands should be placed once the car is lifted.
    On the frame or the pinch weld.
    Define "frame" on a protege5 since there is no true frame? The pinch weld, for those who are not aware, are the reinforced notches a few inches long about a foot behind the front tire along the rail and a foot in front of the rear tire on the same rail.
    read the manual. it'll show you a spot near the sides of the car that has two bumps/notches that mark the area that the stands should be placed
    Yes, except the manual does not say where the place the jack if you are saving the pinch welds for the jack stands. Be specific to be helpful.
    Anyway, I just wanted to provide some background for why I was starting a new thread and this is where we should begin. I have heard some good ideas and some decent ideas that lack any proof and I have heard some downright stupid ideas, so lets try to discuss our methods and certify where we are coming from with logic and discussion.
    I personally have lifted the car at the locations recommended by the owner's manual, while placing the jack stands under the bolt that connects the lower control arm to the subframe of the car. Some say this is a bad idea and I *MIGHT* agree, except in that the forces that are sometimes applied to this point of the suspension and frame can be very high in certain driving conditions, which would lead me to believe that this part of the car is very solid and strong and probably won't have any trouble holding the static weight of a vehicle that is not in motion. I have held the front end of the car on two jack stands in this exact configuration for a week and did not receive any damage. So I would probably conclude that this is a suitable method. If anyone has obtained damage from using this method, please share. Speculating that there is potential to cause damage in this area is fine, but more specific, number supported information would be more helpful if possible. Does anyone, by an offhand chance, know how much this weight these lower control arm connection points can hold for instance?
    Moving on to another method. I have read that some people on the forum have jacked the car up under the front cross member. The advantage to this method is that it lifts the entire front end of the car off the ground so that jack stands can be placed on either side of the car simultaneously. This method also seems logical in that you are jacking directly under a motor mount and the motor is attached to the car via 3 other strong mounts so the stress is distributed amongst multiple load bearing areas in the engine bay. On a high side estimate, I figure about 60% of the total weight of the car will be held up by the jack, which comes out to about 1650 pounds. Divide this figure by four (the number of engine mounts) and we come up with 412 pounds per engine mount. Although the distribution between each of the mounts won't be equal and the engine is actually a load bearing member in this scenario, the numbers should be reasonably close. I do not think that these figures are all that extreme especially for only a short period of time before the jack stands are placed in your two chosen locations. Feel free to argue against this if your experience or knowledge outweigh mine because I am not a mechanic or an engineer by trade.
    Using this front crossmember jacking technique, where should the jacks be placed? I am leaning towards the pinch welds, but having had success with the lower control arm mount points, I am inclined to think that this is a reasonable method as well (you can see how I placed a jack under the lower control arm mount point in a picture below, fyi). For history's sake, some users have mentioned that the pinch welds have bent during lifting or while holding a jack stand. I have never had a problem with this, but I have only lifted the car at these points and have thus, never placed a jack stand here for a prolonged period of time. Has anyone received damage to the pinch welds when placing a jack under them?
    I have read the following:
    the cross member under the tranny is a good spot. there is a ball that sticks out you can jack it from there and then put your jack stands on either side
    this opinion is supported by another similar post:
    The front jacking point for raising both front wheels at once is the round dome shaped bracket under the transmission/engine. It's a little towards the driver's side and very near the front bumper. Put the jackstands under the frame rails about a foot in towards the center from the front door hinges and behind the front wheels. This will solidly support the front of the car
    The latter of these two opinions is from, user MSP Pro, who is involved in autocrossing and might have a stronger grasp on how to properly jack up a Protege based on automotive experience.
    Anyway, I have included a picture of the area underneath the front cross member directly below the front engine mount. At the top of the picture you will notice a convex circular protrusion in the crossmember with a small hole in it. I am assuming that this is a location that the user above was describing, BUT I AM NOT SURE so can somebody confirm?
    Some people do not believe that this area is a good jack point as stated below:
    That support is not designed to handle weight like that or to that amount. I do not suggest lifting from there.
    This comment was provided by the same user who said that its easier to use a lift (user: BlkZoomZoom), so this may merely be a case of easy dismissal of another's technique, or it might be good factual information, but with what is provided, it is hard to say.
    I have also heard of someone jacking up the front of the car using a cross member behind the engine, but after looking around this area, I was not able to find anything that looked sturdy enough to convincingly hold the went of the whole front of the car. If anyone has any info on this or pictures, please post them.
    NOTE: You will see that I have placed a jack under the driver's side front pinch weld, and am backing that up with a jack stand under the lower control arm frame mount point. Do not simply rely on a floor jack to hold up a car, especially if you are working underneath. They have been known to fail from time to time, although it has never happened to me directly. Some people go a step further and backup their jack stands by placing their removed wheels under the side rails of the car in the event that the jackstands fail, thus causing the wheels to hold the car up enough so that you can get out.
    In regards to jacking up the back of the car, I have another picture to share depicting the area where the rear suspension components are secured to the inner sub frame of the car:
    Is this the location that people have been using the jack the rear of the car up? I assume the jack should be placed behind the flimsy looking hollow box piece that sticks down?
    In closing, I was hoping to shed some light on an often asked question and wanted to invite other users to share their experience on this subject. Does anyone have any other methods they use as they pertain to floor jacks and jack stands? I am trying to avoid speculation and it would also be nice if certain methods were not dismissed as wrong without some evidence to back it up if possible. Heck, I might even find out that I have been doing this wrong the whole time myself!
    Regards,
    Zach
    2002 Protege5
  2. #2
    Yellow Hatch Mafia Lives! TreFlip999's Avatar
    Potential Scammer!
    Donated: $25
    2003 Yellow Beast
    Join Date
    Sep 2006
    Location
    Lynnwood, WA
    Posts
    1,981
    wow...thanks alot for that..you have just enlightened me!
  3. #3
    Yellow Jacket Keno1542's Avatar
    Mazda MP3
    Join Date
    Oct 2005
    Location
    Georgia Tech
    Posts
    1,122
    subs
  4. #4
    Banned jeg0024's Avatar
    2002 22V Protege DX
    Join Date
    Sep 2006
    Location
    Kissimmee, FL
    Posts
    4,841
    I always just jack my car up like this...
    *not my car and not my jack*
  5. #5
    lil' red susamafone's Avatar
    Red '03.5 Protege5
    Join Date
    Dec 2005
    Location
    Round Rock, TX
    Posts
    839
    those are the two places i use to jack my car. no problems to date either. granted, i have the gt spec reinforcement pannel on the rear, but i place the jack right on that.
    [-ViS OEM Style Carbon Fiber Hood-][-Tokico Illuminas-][-Megan Racing Springs-][-GT Spec Rear V Brace-][-GT Spec Rear Reinforcement Panel-][-GT Spec Rear Strut Bar-][-GT Spec Trunk Brace-][-GT Spec 4 Pts. Cross Linkage Bars-][-GT Spec Lower Front Tie Bar-]
  6. #6
    Registered Member
    Protege5
    Join Date
    Jun 2006
    Location
    Denver, CO
    Posts
    75
    Jeg024, do you jack up at the pinch weld and place the jack on part of the unreinforced rail or vice versa? Aren't you worried about bending the rail?
    Susamafone, what do you mean those are the two places you use to jack up your car? What parts specifically?
  7. #7
    Registered Member NCZ13's Avatar
    Join Date
    Jan 2007
    Location
    San Marcos, CA
    Posts
    3,928
    thats the two points that i use as well. i havent had any problems with it crushing or anything, nor have had any weird noises. good thread my friend. this should be stickied.
    i had to search around when i did my suspension to find the proper front and rear jack points
    *and i think he means those two points in the pictures, that, little mound, and the hollow box
    2008 Mazdaspeed3
    1986 mazda rx7
    2002.5 mazda protege5 (sold 12/26)
    FS RULES:
    http://www.mazdas247.com/forum/showthread.php?t=98864
  8. #8
    Registered Member NVP5White's Avatar
    2003 Mazda Protege5 - Pure White
    Join Date
    Apr 2005
    Location
    Bethesda, MD
    Posts
    839
    All of these points are jacking points. Which to use depends on what work you are trying to do in the car. For rotating direction tire front to back I jack on the side pinch weld and swap front and rear tires.
    For all work done on the front of the car where access underneath the car is required I will jack on the longitudinal engine support by placing a floor jack under the ball in front.
    Jacking for the rear is done in the position indicated.
    If I need to get the front higher in the air to work on, say, the shift linkage, I'll place the floor jack under the front suspension cross member with a 2x4 between the jack and cross member.
    I think when I get a house, if I'm still working on cars, I'm going to invest in an inexpensive pneumatic lift similar to this:
    http://www.americasprideonline.com/2...-1.ViewProduct
  9. #9
    2002 22V Protege DX
    Join Date
    Sep 2006
    Location
    Kissimmee, FL
    Posts
    4,841
    Quote Originally Posted by PowrSlave View Post
    First off I have ran my car into a ditch before and it sat on the pinch weld part and as far as I know nothing got bent. I've never worried about bending anything, I guess I just dont know that I needed to worry about it. I always jack up my car on the pinch welds in the front and rear for any and everything I do under my car. I just never knew any better, and ignore the wheel ramps in the 2nd pic, my dad made me put them under there "just incase". Not to mention now that im lowered I can hardy get the jack under the pinch welds, I have no idea how I would reach any of the other points mentioned. I use the same 4 points used with the 4 point lift like the one in the link above, so should I be worried about this?
    Attached Images Attached Images
  10. #10
    Registered Member P-Funk!'s Avatar
    Lancer Ralliart Sportback
    Join Date
    Jul 2002
    Location
    Chesapeake Beach, MD
    Posts
    3,291
    1. Yes, those (in your pix) are the preffered jack points for lifting the whole front and/or rear (i.e. doing brakes, roating tires, etc...). Good jack stand placement as well.
    2. I emphasize with you the importance of jack stands. Picture the car on you (doing the dead bug) or the front end sammed on the ground sitting on the rotor (and try jacking now with the car that low).
    3. Do not rely on the flimsy spare tire jack that came with the car. It is for infrequent use to lift one wheel off the ground ONLY! Spend the ~$100 for a floor jack. Bottle jack if you can't afford that.... I have NEVER regretted getting my WallyWorld floor jack and have used it countless times!
    Yes, i recommend a stickee for this topic.
    I used to have a
    Black Mica Protege5
    Mods:
    MP3 ECU
    Hawk Pads
    OBX Header
    AWR Mounts
    Tokico Blues
    Eibach Pro Kit
    Underdrive Pulley
    Kartboy Bushings
    ThermoBlok Spacers
    Kumho ECSTA AST tires
    Fabricated Ground Wire Kit
    VTCS-Less Intake (Ported)
    Fabricated SRI w/ K&N Filter
    Fog lights on with parking lights
    Audio:
    Kenwood Head Unit
    Kenwood Mono Amp
    Custom 10" Enclosures
    Boston Accoustic 1" Tweets
    Rockford/Fosgate Punch 50
  11. #11
    Registered Member
    Protege5
    Join Date
    Jun 2006
    Location
    Denver, CO
    Posts
    75
    Yeah so the consensus so far is that the jack stands can be placed under the bolt where the front lower control arms attach to the frame or the front pinch welds along the side of the car. Both seem to be adequate locations when lifting the whole front of the car at once.
    In regards to lifting the whole rear of the car at once, you might want to stick with the pinch welds on the side of the car in front of the rear wheel well, for simplicity.
  12. #12
    1 OWNR MSP BOOSTR's Avatar
    Join Date
    Oct 2003
    Location
    wildwood fl
    Posts
    4,031
    I've always used both of those points shown in the pics above when I need to set the car on jack stands. If I am only going to rotate tires, I slip the jack underneath the car on the frame rail(that's what I call it) directly below where the front mirror sits and lift the car off of both wheels that way. Front jackstand placement for me is behind the front tires on the frame rail. Rear jackstands go on the rear crossmember. I use a professional style floor jack.
  13. #13
    out to pasture... MazdaSpeeder's Avatar
    Protege5 (5-spd)
    Join Date
    May 2007
    Location
    Kentucky
    Posts
    2,653
    subin- Great thread and excellent in-depth research!
    For Sale: MP3 ECU Genuine (not flashed)
    Alpine Head Unit & Pioneer Speakers - MSP Radio Pocket - SLS Gauge Rings - Greddy Weighted Shift Knob - Momo EBrake
    35% Front, 25% Rear Tint - DDM 4300K HIDs - Wipac Fogs - Stoptech Pads - DRT Slotted Rotors - Optima Red Top
    NGK Long-Reach Plugs - 1.8L Coil Packs - Fiamm Low-Tone Horn - MP3 ECU -
    RR Racing UDP - Simota Twin Charger CAI - Magnaflow Cat-Back
    SLS Midpipe - Tsudo Header -
    Corksport Exhaust Hangers - AWR & RR Racing Inserts - Kartboy SS & Bushings - Sumitomo HTR+ 215/40/16
  14. #14
    TOPLESS!! SlowPro98's Avatar
    Donated: $20
    02P5, 98ES,95miata
    Join Date
    Oct 2004
    Location
    Vernon CT
    Posts
    1,939
    How I jack up my ride. Iíve yet to have any issues.
    - secure the e-brake
    -choke the rear wheels with a 2x4
    -get the jack stands ready, 2 clicks up
    -get the floor jack, and spare tire jack out and ready. I have to use the spare tire jack to get started, my floor jack canít fit under the lowered height.
    - I lift and block on the pinch welds. Iíve never had a problem with this and Iíve done it on all of my cars.
    -Secure the jack stands under the car. Left side, then right side. Once the right side of the car is lowered on itís jack stand, I make sure the floor jack still has some lifting tension. There is nothing wrong with double redundancy.
    -stand up and push the car. If it wiggles or drops. You funked up and need to secure the car.
    I Pay for Referrals
    "So nowadays, they can call me old fashioned But it's way too much cash to see blue lights flashin'~ So I guess the moral of this here class is~Life about who make it now not about who make it the fastest " T.I.
  15. #15
    Luv my MP5! MadBiker's Avatar
    2002 Protege5
    Join Date
    Jan 2003
    Location
    Funabashi, JAPAN
    Posts
    498
    I know I'm chiming in late on this thread but thanks to PowrSlave for the awesome photos.
    Just finished my swap to my winter wheel set on the wifey's 1998 (or thereabouts, can't tell with the Heisei calendar they use here) 1.5L Familia wagon.
    I jacked the front end up on the ball (didn't bother using jackstands) and changed out the 2 front tires. Although the ball isn't centered on the car, it lifted the front end fine (but man that had me scratching my head and voila!! I found this thread).
    Then jacked up the rear end by jacking *on* the hollow metal piece (not on the plate portion behind it). I did see it bend a bit but it worked. Again, I didn't bother using jackstands on the frame rail on both sides of the car. I swapped out the 2 rear tires and was done.
    Great thread, thanks for all the posts. This forum kicks butt!!!
    '02 Midnight Blue MP5 (updated 10/12/2010)
    5 spd, Moonroof, Chrome 16" OEM Wheels, Roofracks Off
    Interior / Stereo: Clarion HDD Navigation System, Mazda Logo Seatbelt Pads, Door Chime Off
    Exterior: Front Mask, Rfracks Off, Rally Twin Edge Wipers, Louder Horn, Rust and Blisters on hood and various scrathes and dents (hahaha)
    Engine: AWR Motor & Transmission Mounts, Corksport Shifter Bushings
    => Beastification Underway!!!
    '05 Atenza Sport 23S (updated 10/12/2010)
    5 spd, Red, Sunroof, HID lamps, 6 CD Bose Stereo, DVD Navigation System,
    Atenza Sport Yellow Accent Floormats, Mazda Yellow Seatbelt Pads, Mazdaspeed Seat (Driver Side), 18" Work Emotion Kai Wheels
    pics here => http://www.msprotege.com/forum/showthread.php?t=101142&page=2&pp=15)
    '98 Mazda Familia (Updated 10/12/2010)
    1.5L Red Auto w/Sport Body Kit, Clarion HDD Navigation System, Door Chime Off, 15" Monza R v.III Wheels w/Duraluminum Nuts, Eurotone Horn
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
