P0455, changed gas cap but still get code
rtfm17
I've been fighting with a stubborn P0455 that's still there even after replacing with an OEM gas cap.
If it's not the gas cap, what else can I check?
What conditions that trigger the PCM to do an EVAP test? Is there an easy way to trigger one (without just random driving, waiting & hoping)?
Thanks!
Doh!!! Sorry. Darn thing is making me crazy.
1999 Protege LX 1.6L.
Sine then I've also replaced the purge solenoid, used a hand vacuum pump to verify the line from intake manifold, vacuum chamber, and charcoal filter have zero leaks. So front to back is A-OK.
Have you tried undoing the battery for 10 mintes to clear the codes?
I'm guessing theres an easier solution, like a fuse to pull for just a moment, w/out having side affects of resetting some stuff, like your radio presets, etc... (my '99 miata has a fuse i just pull for ~30 seconds to reset the computer)
I can clear the PCM, which clears the code & all onboard tests. (I have the autoenginuity OBDII package). That's no problem.
Problem I'm having is getting the PCM to actually *run*the EVAP test. I can't even tell if any work I did made it happy or not for several days.
I did get a service manual, and we've tried to reproduce 'mode 4', there is a cool-down cycle. It took 3 days to get it to trigger (and it promptly threw a P0455 again, arrrgh!)
(Manual also hints if I had a Mazda OEM scan tool (about $3-5k) there's probably a 'run test' button I could press...)
Any ideas? Suggestions? Magical incantations? ;-)
