Upgrade your Mazda with High Quality Parts at Great Prices from James Barone Racing!
Page 1 of 3 123 LastLast
Results 1 to 15 of 34
Thread: Belt Squeal? Or from something else?
  1. #1
    Why are you looking here? Coqui258's Avatar
    Donated: 5$
    2003 Black Mica Protege5
    Join Date
    Jun 2003
    Location
    Philly, PA
    Posts
    817
    When I start my car after it's been sitting for a while (i.e. in the morning), I hear a squeal similar to the noise when a belt is loose, BUT, the noise does NOT get louder when I accelerate. The noise stays steady until the car is warmed up, then it goes away.
    It seems it might be the water pump? Would it squeal if it's going?
    Any ideas?
    Money saved for turbo: $0.35, a snickers bar, and 3 toothpicks
    HIGHEST BID FOR THE SNICKERS BAR:
    02-22-2004 02:07 PM
    Spicyzoomzoom
    two bajillion and 6 dollars times infinity plus two
  2. #2
    P5 Picture Whore MTV's Avatar
    2002 Protegé 5
    Join Date
    Feb 2007
    Location
    Montreal
    Posts
    1,056
    My belt used to squeal after a cold start. The squealing got louder when I accelerated though, that's how I knew for sure it was the belt.
    I sprayed some WD-40 on it and it went away. Try it, if it doesn't go away then it's not the belt.
    Matt
  3. #3
    Registered Member
    Join Date
    Jan 2008
    Posts
    1
    I too have the exact same problem as Coqui258....Cold start squeal until warmed up.....Car is brand new 07-Mazda3 with only 2500kms.
    Dealer kept it overnight to hear the sound in the morning and they replaced the tensioner......But, the noise seems to still be there - only quieter though.
    I think since the belt is still new, it needs to stretch a little? Anyways, I'll let it be for now and hope it goes away......If it still makes the noise, I'll have to return to the dealer.
    Many threads on this and no specific solution. Have to wait it out to know for sure.
  4. #4
    2002 Protegé 5
    Join Date
    Feb 2007
    Location
    Montreal
    Posts
    1,056
    wd-40
  5. #5
    Registered Member P-Funk!'s Avatar
    Lancer Ralliart Sportback
    Join Date
    Jul 2002
    Location
    Chesapeake Beach, MD
    Posts
    3,290
    A bearing that is getting ready to fail would do the same. Have a mechanic listen with a stethoscope to find out which one..
    I used to have a
    Black Mica Protege5
    Mods:
    MP3 ECU
    Hawk Pads
    OBX Header
    AWR Mounts
    Tokico Blues
    Eibach Pro Kit
    Underdrive Pulley
    Kartboy Bushings
    ThermoBlok Spacers
    Kumho ECSTA AST tires
    Fabricated Ground Wire Kit
    VTCS-Less Intake (Ported)
    Fabricated SRI w/ K&N Filter
    Fog lights on with parking lights
    Audio:
    Kenwood Head Unit
    Kenwood Mono Amp
    Custom 10" Enclosures
    Boston Accoustic 1" Tweets
    Rockford/Fosgate Punch 50
  6. #6
    Registered Member
    Join Date
    Aug 2005
    Posts
    162
    Did you ever figure out what it was?
    Ours has been doing that lately too - only at first start up in the morning when it is cold out. And the volume has been going way up lately. I replaced the belts thinking maybe that was it, but that did not affect it at all. I even re-tensioned the belts this morning and then started the car again and it still did it. Intermittently too - not constant - comes and goes. Then goes away once warm. I listened to it with the hood open and it seemed to be coming from the front of the engine, not the back, so I am guessing it is either the PS pump or the AC compressor. Could be the alternator, but didn't sound like it was coming from back there to me. These cars do not have belt driven water pumps, eh?
    Any way to figure out which component is the culprit? I would hate to have it fail with my wife driving and then cause even more damage or strand her somewhere. But not sure what else I can do other than replace everything, which is a Pain.
    Car is a 03 P5 w/ 82K miles
  7. #7
    Registered Member zutalores's Avatar
    '03 P5
    Join Date
    Feb 2008
    Location
    Great Lakes, IL
    Posts
    17
    Mine squealed upon initial startup and just chirped for awhile afterwards. Come to find out, it was my harmonic balancer. It shifted ever so slightly and caused the laternator belt to rub fuuny on the pulley. Unfortuantely I had to change the balancer to fix it. I would say to definately bring it to a garage and have a mechnic break out the stethoscope. You don't want to tear a belt.
  8. #8
    Registered Member
    Join Date
    Aug 2005
    Posts
    162
    Quote Originally Posted by zutalores View Post
    This is more of a scream that you can hear for blocks. There is no way anyone is going to be listening to this through a stethoscope unless they want to permantly damage their hearing!!
    I need to pull off one of the belts and fire it up in the AM one morning to see if I can narrow down which accessory drive is causing the problem. There isn't much running on the drives on these engines, so it won't be that hard to narrow down. Seems likely it is the water pump or PS pump - sounds like it is coming from the PS pump area, not as likely the alternator.
  9. #9
    Registered Member
    Join Date
    Aug 2005
    Posts
    162
    well - it has been getting worse as I knew it would. so today I pulled the belt that runs the PS and AC and confirmed the squeal is gone w/o that belt running. The AC pulley rolls freely with no friction at all, plus it should be freewheeling with the compressor off now in the winter. So pretty much has to be the PS pump - which is where the sound seemed to be coming from when I listened to it. The pulley seems stiffer than it should be.
    So I ordered up a rebuild from the dealer, plus the pulley - I don't want to take any chances so will just replace it all.
    I drove the car w/o the belt hooked up and it wasn't that bad w/o the PS - I could live with it. Wife would complain, so I hooked the belt back up. Squeal came back a few times to let me know it hadn't miraculously gone away or anything.
    New pump should be here early next week. R&R looks pretty straightforward.
  10. #10
    Registered Member kura808's Avatar
    '02.5 MP5
    Join Date
    Dec 2006
    Location
    HAWAII
    Posts
    996
    hmm its been a while since i last took my p5 out in the early morning. yea it does only happen when its cold out. when i started her up, i hear a sqeaking sound then after a little while, it went away. btw my ac wasnt on. when i heard it, i was like damn thats loud haha
  11. #11
    Registered Member
    Join Date
    Aug 2005
    Posts
    162
    Quote Originally Posted by kura808 View Post
    Well - ours progressed from only first thing in the morning when cold to pretty much all the time at low engine speeds - especially idle. It is bad enough now that I had my wife stop driving the car and drive our Suburban until I can get it fixed. I don't want that thing seizing up and throwing the belt and possibly taking out the other belt. The PS belt I'm not worried about, but the other one runs the water pump - don't want that one off. Anyway, I have a PS pump on order from the dealer - should be here tomorrow. Hopefully I can get some time to install it on Wed.
  12. #12
    '02.5 MP5
    Join Date
    Dec 2006
    Location
    HAWAII
    Posts
    996
    i think some1 said that the belts dont interfere wit the other ones. so if one goes, it wont affect the others. dont quote me on that hehe
  13. #13
    Registered Member
    2002 Protege5
    Join Date
    Dec 2007
    Location
    Decatur IL
    Posts
    674
    yeah in helping to diagnose without pulling the belts you can turn the A/C ON - it it goes away it's probably the A/C clutch bearings. Then can steer while idling to load up the steering pump and see if that makes it worse. Then turn on the lights on high and see if the alternator is seemingly at fault. These don't always work, but are easy to try to help pinpoint a squeal. I once had a low-frequency vibration in a 626 that I finally traced to a slightly loose power steering belt. I figured it would have been squealing, but not a peep. But you really do want to figure out if your timing belt pulley bearings are going. Last I read on here the MP5 motor in non-interference, but that would still be mighty inconvenient.
    02 Protege5 - Vivid Yellow - 230K mi
    flywheel, clutch, UR pulley, Injen, OBX, MagnaFlow, PIAA fogs, Jensen head, sub, & 6x9s. On my 7th Mazda!
  14. #14
    Registered Member u812many73's Avatar
    Donated: $5
    02 p5
    Join Date
    Aug 2006
    Location
    Cocoa Beach, fl
    Posts
    349
    are you sure it just wasn't the belt being too loose? The belts seem to have a small window of adjustment, too tight and they squeel, too loose and they squeel. That would be the first thing i checked. I just play around with it til it quits. And WD-40 seems like a bad way to fix it. Just a cover up really, it will prob just come back eventually.
    Picture Thread
    2002 protege5-turbo, progress springs, Mazdaspeed sport exhaust, Mazda6 brake upgrade, MSP short shifter, dave b gauge rings, s2000 antenna, kartboy shifer bushings, black housing headlights. misc stereo upgrades.
  15. #15
    Registered Member
    Join Date
    Aug 2005
    Posts
    162
    Quote Originally Posted by u812many73 View Post
    100% sure. It was intermittent and only did it when cold and would just stop for no reason. This is not a belt squeal - much louder and more like a scream. A slipping belt just cannot make that loud of a sound. Very clearly the sound of a bearing going bad. I've heard this before on other cars. Anyway, I replaced the PS pump and the squeal is gone.
Similar Threads
  1. UDP belt squeal
    By PR5Matt in forum Mazda Tech & How-To
    Last Post: 07-16-2008, 08:35 PM
  2. Belt squeal on warmup
    By Gasological in forum MSP Problems
    Last Post: 08-24-2007, 09:01 PM
  3. Belt Squeal When Cold
    By Demoniam in forum Protege5 Lounge
    Last Post: 11-29-2006, 10:57 PM
  4. Belt squeal!?!
    By StealthWyvern in forum Protege5 Lounge
    Last Post: 06-23-2006, 09:38 PM
  5. CG Lock lap belt tensioner
    By SilverBulletES in forum Protege Performance
    Last Post: 05-12-2005, 04:06 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
