CorkSport.com is MAZDA PERFORMANCE!
Results 1 to 7 of 7
Thread: Where is the MAP Sensor or the Barometric Sensor at..?
  1. #1
    Registered Member Protegelx's Avatar
    Join Date
    May 2007
    Posts
    25
    hi all ,i just have check engine on and got it diagnosed.
    "The PCM has determined that input from the manifold absolute presure sensor or the barometric pressure sensor has changed too much, without a corresponding change in engine operating conditions."
    What does it mean?
    I also had this question ,how can i clean the mass airflow sensor? Does an 1.8 MAS fit my 1.6 and would it do anything?
  2. #2
    Banned Witchdoktor's Avatar
    Donated: $20
    99 LX
    Join Date
    Feb 2003
    Location
    NC
    Posts
    1,888
    what cel # ?
    a 1.6 maf is not interchangeable with a 1.8/2.0 maf.
    cleaning the maf - stores carry a spray specifically for cleaning mafs
    the map sensor is located in the corner of the engine bay near the passenger side windshield, it has a mitsubishi logo on it.
  3. #3
    Join Date
    May 2007
    Posts
    25
    the cel # IS PO106
  4. #4
    More Power Made Me Slower Joost27's Avatar
    Donated: $5
    2000 Mazda Protege ES V6
    Join Date
    Jul 2006
    Location
    Hinsdale, NH
    Posts
    618
    its not the MAF, theres a pressure sensor, its mounted on the left strut tower in the engine bay(if your looking from the bumper back toward the engine) its a little Mitsubishi Sensor, with a plug, and two vacuum lines running to it, make sure the lines are connected, ive hit them while detailing under the hood and popped one off then got that same CEL code.
    2000 Mazda Protege ES 1.8l >> 2.5l v6
    KLZE 2.5L v6 Straight Neck, CAI & PaceSetter v1 Headers, KL36 ECU, JE50 VAF, 14* Timing, AFPR @ 40psi, Braille B2015 Battery, Tech Edge WBO2
    03.5 MSP Axle Back, AWR 95 Duro FMM, RMM, Pass. and Trans Inserts, MFactory Helical LSD, MSP Axles
    03 ES 5-Lug Swap, MZ6 Front Brakes, 626 Rear Brakes, Gunmetal Rota Torque 17x8 +42, Bridgestone RE070 225/45
    Tokico HPs w/ Eibach Pro-Kit, MSP RSB, Corksport STB, KMR Tie Bar, KMR Rear V-Brace, Harness Bar, 01-03 Sedan Front Lip, P5 Skirts
    03.5 MSP Rear Lip, MSP Floormats, GReddy Counter Weight, MSP Door Sills, Nardi Torino Steering Wheel, Sparco Pedals
    MZ6 Headlight & Wiper Switch, B&M Shifter, DGM C/F Arm Rest, Cluster, and Glove Box Trim, 03 ES Black Interior Swap
    2006 Mazdaspeed6 GT VRM
    SURE Aeros | HTP TIP | CS TMIC | CS HPFP | M2 DP | XSPower Manifold | Cobb AP v3 | ITV22 | DO Methanol | H&R Springs
    KLZE Project Complete
  5. #5
    Join Date
    May 2007
    Posts
    25
    ok i found the sensor with the mitsubishi logo on it. Yes, there was a vacuum line loose. I disconected the baterry for about half an hour. Cel light off for about 2 days. Then it came on again. I know that i need to check it again to see if its the same code.
    Thanks guys for the help. Is it true the 1.6 proteges recalled them for difective MAF sensor?
  6. #6
    BLUE LIGHTNING POLARBEARsMP3's Avatar
    mazda protege mp3
    Join Date
    Feb 2007
    Location
    Troy, MI
    Posts
    163
    does anyone have a pic where this is located on a 2.0L
    MP3 #959
    Engine mods- MSP Turbo, MSP ECU (unflashed), Custom Spearco FMIC, TurboXS RFL BOV, Injen CAI, Dual Stage Boost Controller at 5 and 10, FCD, FPR, Vibrant street power catback, AWR FULL mounts, B&M SS, SPEC STAGE 2+, FIDANZA Flywheel, HKS TT.
    App. Mods- BUDDY CLUB BODY KIT, APC CF hood (painted), 18inch Focal, Drill/Slot Rotors, also SOON TO BE D2 racing coilover.
  7. #7
    Registered Member redd1101's Avatar
    04 mazda 3 hatch
    Join Date
    Feb 2012
    Location
    paterson nj
    Posts
    7
    i have a 2004 mazda 3 hatch engine light came on , p2228 baro sensor low circuit , i jus changed de baro sensor , n reseted de car n check engine came back saying the same thing , at this point im freaking frustrated what do i have to change does anyone know ,also does anyone by any chance have a pic of de map sensor baro sensor maf sensor let me know thanks
Similar Threads
  1. Replies: 13
    Last Post: 05-26-2013, 11:40 AM
  2. barometric pressure sensor?
    By m.o.b.s. in forum Mazda3 Engine & Transmission
    Last Post: 09-23-2010, 11:23 AM
  3. WTB: MP5 AC pump sensor? and Trans sensor?
    By McBadass in forum Completed Transactions
    Last Post: 04-08-2010, 08:52 AM
  4. Boost Sensor aka map/baro sensor
    By mesa3 in forum Mazda3 Engine & Transmission
    Last Post: 05-21-2009, 05:37 PM
  5. WTB: cam sensor and coolant temp sensor
    By junya1985 in forum Completed Transactions
    Last Post: 08-22-2008, 10:54 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
