PAC-SI SWC adapter works!
Hi All,
Thought I'd let you all know that the PAC-SI steering wheel control adapter, the Jensen VM9424BT all installed very nicely now, working together.
I used the Scosche harness. Scosche will recommend an Antenna adapter cable which is NOT necessary - you won't use it. Also, I ADDED the missing pins for the steering wheel control terminals to the Scosche harness connector - out of the bag these pins were missing, as well as the Dash Illumination pins (I also added these).
All in all I'm very happy with the result. The head unit is AMAZING - very good value for the money. Sound output is crystal clear, plenty loud enough for this vehicle unless you want to annoy people. I've tested it with streaming bluetooth which is a NICE alternative to using the AUX.
Ben.
