Hi.
I have a 2002 Protege and I want to mount this LCD screen (didnt actually buy it yet) in my dash:
http://dynamixcomputers.com/dynamix_708_led_touchscreen.html
Monitor Dimensions: Inner/Screen MM: (165mm(H) x 106mm(V) x 10.5mm(T)
I would like to mount the LCD onto some sort of double DIN mounting kit so that it can simply slide in like a double DIN radio. I want to be able to easily remove the LCD and put it in another car with double DIN if I were to get a new car. Would any of the Scosche kits work?
http://www.scosche.com/scosche_caraudio.aspx?CategoryID=5
Or is there some sort of universal double DIN mount availiable? I cant seem to find the dimensions of these double DIN kits. Do you guys think the monitor will simply fit into the double DIN kit and then I only have to apply bondo to cover up the holes and maybe improvise something for structural support? I would prefer not having to cut into the double DIN kit/plastic housing of the monitor to make it fit.
Advice appreciated. Thanks.
