How much hp can our fuel system support?
chriscecc914
06 MS6
Anyone know how much power our stock pump and injector can support? Ill be going big turbo soon and i dont wanna run out of fuel on the dyno. Ive heard talk of a secondary fuel injector being installed but i would have no idea how to do that. Thanks
The only ways to upgrade the fuel system would be with either secondary port injection (needing a standalone ECU) or perhaps an upgraded high pressure fuel pump and injectors. Neither have been done (at least publicly).
Injectors are good to go for a while, but the fuel pump isn't going to put out the numbers people are hoping for...
Fuel PumpS*
The one in the gas tank is the one that could be trouble if people start going 350ish+
The one on the engine block is one that most people dream of having.
I want to say the one on the block is the problem... which ever Mazda Engineers refer to as "The High Pressure Fuel Pump"... which my assumption would be that one...
+1
Although it probably has quit abit of headroom, it is a mechanical pump so it was probably not designed to flow enough fuel to support the HP levels most of us modders would like to see(400~450 whp).
i read somewhere, i wish i could remember where, that mazda had some engineer/tuner man work up the MS6 to over 500hp on the stock fuel system. it seems like i remember reading 550hp. am i on drugs lol, did anybody else read this about the mazdaspeed6? i really can't remember where it was..or if it was even for the speed6 lol
ssinstaller said:
+1
Even with a little headroom this fuel pump might have I doubt this engine can handle any thing over the 400 hp range. As for the speed6 with 500hp, I have heard about it but (yupnope) Its all hearsay. Just a rumor (sad2)
Chris-BE said:
Fuel PumpS*
haha
yes!
it is high volume and high pressure. (the one in the engine bay)
I believe that Speed is a true story, the owner is the director of Mazdaspeed USA. Lives down the street from Atom44watt I think?
Anyways, his is not a stuck fuel system. He has direct port injection. But from what I have gathered, it IS a stock motor (block/head). Which is good,he must be boosting about 25lbs at least.
Latest posts
