VersaTuner - tuning software for Mazdas
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: How to: Fix your trunk leak!
  1. #1
    手前の言葉が俺は聞き捨てよう TheMAN's Avatar
    Join Date
    Oct 2002
    Location
    Dallas, TX
    Posts
    5,568
    My car has been normally parked in a garage/shelted parking for years... with my new jobs the car has to be parked outside... I never really knew there was a small leak in my trunk until the past 6 months when I checked it on the suggestion of the local folks... so my trunk does have a small leak where the jack is... the jack has a little bit of rust now but is still usable
    anyway, according to M-Tip 3245, trunk leaks on the 3rd gens usually are the result of the body seams being cracked due to a minor collision, not the weather strip itself.... my car had a love tap a couple of years ago and so I decided to get off my ass and pull the tail light out and check because the rainy season is here..... :eek:
    Attached Images Attached Images
    TheMAN
    '01 BJFP MT
    '05 BK3P HB AT
    For Protege and Mazda3 info, come see the Protege FAQ
  2. #2
    Join Date
    Oct 2002
    Location
    Dallas, TX
    Posts
    5,568
    as you can see, the seam sealant had cracked resulting in water leakage...
    first I sprayed the area with adhesive cleaner to remove whatever oil and dirt there was
    and very quickly I was able to see that the cleaner went into the trunk... it's hard to see in this pic but it was wet when I took it!
  3. #3
    Join Date
    Oct 2002
    Location
    Dallas, TX
    Posts
    5,568
    next I applied body seam sealer around the affected areas and smoothed it out with a putty knife... yes, I half assed it because you won't be able to see it once you put the tail light back on
  4. #4
    Join Date
    Oct 2002
    Location
    Dallas, TX
    Posts
    5,568
    finally, after letting it dry for about an hour (it takes 6 hours to cure), I applied liberal amounts of touch up paint over the sealer to prevent erosion
    I'll see in the next few days when it rains again if this really fixed it, I'm pretty sure it's fixed
  5. #5
    Join Date
    Oct 2002
    Location
    Dallas, TX
    Posts
    5,568
    this is where seam sealant exists in the rear end of the car... check those areas and fix as needed
  6. #6
    CWP 08.5 MS3 GT xtrememps's Avatar
    08.5 Crystal White MS3
    Join Date
    Aug 2003
    Location
    New Jersey
    Posts
    996
    Awesome write up man. I need to get off my ass and do this. After the heavy rain last month I had a decent amount of water inside on both sides.
  7. #7
    Banned jeg0024's Avatar
    2002 22V Protege DX
    Join Date
    Sep 2006
    Location
    Kissimmee, FL
    Posts
    4,841
    Nice work, and thanks for the write-up! Im so glad I have a garage
  8. #8
    Join Date
    Oct 2002
    Location
    Dallas, TX
    Posts
    5,568
    yeah my jack would be totally rusted if my car wasn't parked in a garage.... I'm glad I have a garage too
  9. #9
    Join Date
    Aug 2003
    Location
    New Jersey
    Posts
    996
    I really wish I had a garage. My car has gotten so much wear and tear from just sitting outside all the time. Oh well.
  10. #10
    Registered Member
    2002 Protege LX
    Join Date
    May 2006
    Location
    Moncton, NB
    Posts
    27
    Here I was thinking I was the only one with this problem. Thanks for the write up, I'll have to tackle this one in the coming weeks.
  11. #11
    Canadian eh? CulRidr's Avatar
    Donated: $10
    Laser Blue MP3
    Join Date
    Jan 2006
    Location
    Ottawa (ON), Canada
    Posts
    2,345
    Awesome write-up! Both of my sides are constantly filled with water, but somehow it hasn't started rusting yet (must be some good rustproofing from the previous owner). Many threads have mentioned it has something to do with the vents to the trunk, so I will try this and see if it works.
    2 question though;
    1: in that picture from post #5, are the bold black lines where the seam sealant is?
    2. I assume once you take the tail lights out that the stripping used for them will need replacing? what do I use to replace it?
    Quote Originally Posted by TheMAN
  12. #12
    Registered Member 99 ProLX's Avatar
    99 Pro 1.6L 5spd (DD) :: '93 300ZX TT 5spd (Garage Whore)
    Join Date
    Jun 2007
    Location
    NY
    Posts
    108
    huh, thought I was the only one
  13. #13
    Registered Member batbl18's Avatar
    2002 Mazda Protegé ES
    Join Date
    Jun 2007
    Location
    Connecticut
    Posts
    12
    When I was cleaning out my trunk on my Protege and vacuuming, I noticed that there was some water on the drivers side indent of the trunk. I vacuumed the water out, and after a car wash it was fine. After a couple of rain storms I noticed a bit of moisture had occurred in the spot again. It was only a quarter or half inch or so of water in that one spot shown in picture 2. Just wondering if any of you have had this occur, or know of where the water could be coming from. Thanks!
    Here is a picture of the general area on the Protege where the moisture is.
    Here is a closer view of the area which is wet.
    2002 Mazda Protegé ES Zoom-Zoom
  14. #14
    2002 22V Protege DX
    Join Date
    Sep 2006
    Location
    Kissimmee, FL
    Posts
    4,841
    did you even read this thread?
  15. #15
    this is a big problem with my car, but only in the drivers side, i went under there once and saw a small lake in there, so i emptied it and thoroughly sprayed rust killer it still fulls up a bit sometimes after a wash or if i drive in rain so i keep a cloth in there and check it every once and a while.
    00MF
Similar Threads
  1. Water in trunk.
    By 03.5MSP in forum MSP Lounge
    Last Post: 04-20-2005, 08:17 PM
  2. Vaccum leak? Help!
    By C-Bass in forum MSP Lounge
    Last Post: 07-12-2004, 06:49 PM
  3. Gauging Interest: Carbon Fiber Trunk
    By SP33D in forum Protege Appearance
    Last Post: 02-25-2004, 11:26 AM
  4. coolant leak / warranty work
    By jus10 msp in forum MSP Lounge
    Last Post: 02-17-2004, 09:54 PM
  5. RE: MSP ECU fix and tunability
    By OrangeAppeal in forum Off Topic
    Last Post: 09-11-2003, 11:39 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
