Get +66HP & +27TQ from your 2nd gen MAZDASPEED3 w/ Hypertech!
Page 1 of 6 123 ... LastLast
Results 1 to 15 of 81
Thread: HOW-TO: Shave Side-Moldings/MS3 Emblem
  1. #1
    Daddy Warbucks Equinox's Avatar
    Donated: $245
    09 370Z Nismo
    Join Date
    Mar 2002
    Location
    Daleville, Alabama (Texan)
    Posts
    2,839
    Items for Sale
    Hey guys I previously made a how to, to remove the side moldings way back when for the protege5, and figured I'd do it again for the Mazdaspeed3/Mazda3.
    Here we go!
    What you will need:
    1 x 3M Adhesive Remover
    1 x Bondo Putty Knife
    1 x Paper Towel Roll
    4 x Kitchen Garbage bags
    1 x Awesome Meguiars Car Wax (Love the smell)
    1 x Roll of Painters Tape
    1 x Bottle of Windex
    Note in this picture I forgot a couple things I have on the list, however, it does give you a good idea of what the 3M adhesive remover looks like, as well as the putty knife. I bought the 3M stuff in the paint section of a local automotive parts store, next to the rice parts aisle, lol.
    First thing you want to do is take your 3M adhesive remover and make a small punture in it, so you can sprinkle the stuff, instead of pour it all over your car.
    Now, you will need to run a length of painters tape along the bottom edge of your door guard. When you put it on, however, you want to leave the bottom edge of it not stuck against the car. Then take one of your garbage bags and rip it down along the seam on both sides, so you have a straight edge, and slide the edge up into the bottom edge of the tape, hanging it down like a curtain over your rocker panel/side skirts. The reason for this is so you don't let the adhesive remover drip down into the seam of your side skirts, possibly loosening them, as they are also held on by adhesive along the edges. Then, put about four inches of tape along the top edge of the door guard, at the tapered portion, so you have something to rest the putty knife on, when pulling up the guard.
    Next, sprinkle your 3m adhesive remover along the top of the guard, letting it run down into the door guard, seaping into the double sided tape. I let the 3m stuff work for about 3 minutes before I started working on it again. Take your putty knife, and clean off any plastic burrs, that might cause small scratches in your clear. Then, take the tip of the knife and slip it up under the tapered edge of the door guard, and pull up the first inch, just enough to give you a handle to grab. Then, without the putty knife, grab the edge you pulled up, and pull it the rest of the way, pealing it off the car.
    Majority of the doublesided tape should come off. My car was only a month old just about, when I did this, but it worked just as well on my protege5 when I had it for 6 months, before trying this. This is what wil be left behind.
    Using your fingernail, scrape away the large excess adhesive, then, 8" sections at a time, take a square folded peice of paper towel, and sprinkle along 8" of remaining adhesive, wiping excess remover on your towel, then in small circles, 'wax off' the adhesive. If you work in 8" sections or smaller, with the remover, it should come away having done this routine once or twice.
    Your tape may leave some adhesive behind, so I just used windex to do the final clean up.
    All you have left to do is wax the panel, so the drying behavior matches the rest of the car, and there will be no trace it was ever there. You can apply this same tactic to the rear Mazdaspeed3 emblem. Unfortunately the Mazda3 emblem has holes behind it, so don't try this, with the Mazda3 emblem.
    Previous owner of an MP5T
    '09 370Z Nismo, Platinum Graphite
    Bolt-ons: GTM 3" CBE, B&M Short Shifter, GT-SPEC 4-point Ladder Bar, GT-SPEC 2-Point Lower Tie-brace, GTM Front Mount Oil Cooler, K&N Drop in filters
    Rice: Carbon Kevlar Bride Gias Racing Seats, PWJDM Carbon Kevlar Battery & Fluid Res & Radiator Cover, AutoEXE Carbon Fiber Shift Knob, Kenwood DNX9140 DVD/GPS 7" Radio, Rear View Camera, Windshield Tinted 50%
    '96 RX-7 JDM RHD, Red
    Bolt-ons: HSC LS2 6.0L V8 Conversion, Borg Warner T-56 6-speed Trans, HKS Hiper-Max III Coilovers, HSC Headers and 4" Exhaust, BF Goodrich 285/30/18 Rears, Zex 100hp Dry Shot System
    Rice: Seibon Fenders and Hood, '99 Tail Lights and Front end, Racelogic Traction Control, Zex Twin Nitrous Purge, Optima Red-top Drycell in trunk, Racing Beat Type II Wing
    '07 MS3 GT, Black SOLD
    '02 MP5-T, Silver SOLD
  2. #2
    Donated: $245
    09 370Z Nismo
    Join Date
    Mar 2002
    Location
    Posts
    2,839
    Items for Sale
    Can someone verify that the mazda3 has the same side moldings as the mazdaspeed3?
  3. #3
    Registered User Euphorism's Avatar
    2007 MS3
    Join Date
    Feb 2007
    Location
    Nampa, ID
    Posts
    126
    Items for Sale
    Quote Originally Posted by Equinox
    in the last picture it looks like a blue 3 in the right missing the door moldings, so i would guess yes.
  4. #4
    MS3Fanatic BlackJack's Avatar
    2007 Mazdaspeed3 GT (gone :()
    Join Date
    Oct 2006
    Location
    Bridgewater, NJ and Norwood, MA
    Posts
    398
    Items for Sale
    Do you know if you can take out the Flying M emblem in the middle?
  5. #5
    Banned jeg0024's Avatar
    2002 22V Protege DX
    Join Date
    Sep 2006
    Location
    Kissimmee, FL
    Posts
    4,884
    Items for Sale
    Quote Originally Posted by Euphorism
    Looks like a MP3 to me?
  6. #6
    Donated: $245
    09 370Z Nismo
    Join Date
    Mar 2002
    Location
    Posts
    2,839
    Items for Sale
    Quote Originally Posted by BlackJack
    Has two holes behind it, so I wouldn't suggest it. You'd have to weld in the holes then repaint the panel.
    Also yes that's MP3Girly's MP3, not a blue mazda3. MP3s don't come with sidemoldings.
  7. #7
    No more MP3...no more MSP MP3Architect's Avatar
    Donated: $24.45
    Join Date
    Jul 2004
    Location
    CT
    Posts
    4,944
    Items for Sale
    yeah i thought that dropped mp3 looked familiar. so your speed3 is here in h-town then eh? man better bring her out next time your in town.
  8. #8
    Donated: $245
    09 370Z Nismo
    Join Date
    Mar 2002
    Location
    Posts
    2,839
    Items for Sale
    Quote Originally Posted by MP3Architect
    I live on an Army base in Alabama, sorry :<
    I deploy to Iraq in June as well, so I won't be back for a lil' while.
  9. #9
    2007 MS3
    Join Date
    Feb 2007
    Location
    Nampa, ID
    Posts
    126
    Items for Sale
    can you take a shot of the ms3 angled from the side with the entire car in the shot? i wanna see how it looks from a slight distance.
  10. #10
    Donated: $245
    09 370Z Nismo
    Join Date
    Mar 2002
    Location
    Posts
    2,839
    Items for Sale
    Sure lemme wait til daylight
  11. #11
    Registered User maczter's Avatar
    '07 Black Mica MazdaSpeed3 GT / '06 Galaxy Gray Mica Mazda3 s GT
    Join Date
    Mar 2007
    Location
    Austin, Texas
    Posts
    176
    Items for Sale
    Nice How-to. I'm no longer scared to try it myself.
    Live in or near Austin, Texas and drive a factory badged Mazdaspeed?
    Check out the Austin Mazdaspeed Club!
    Get more info here.
  12. #12
    2007 MS3
    Join Date
    Feb 2007
    Location
    Nampa, ID
    Posts
    126
    Items for Sale
    i removed my side moldings and speed badge.. but i didnt use any glue remover and it worked extremely well. all i did was get a piece of paper, slip it as far under what i was removing as possible and then took a pocket knife, got under it with the paper protecting the paint, pulled up till i could get my finger under it, and pulled. came right off without any tape left on the car. i think when you use the glue remover you actually separate some of it from the molding and thats why there was leftovers on the door. when i was done all i had were very think lines of dirt where the moldings use to be.. took some car wash concentrate on a rag and rubbed the sides down.. perfect.
  13. #13
    Join Date
    Mar 2007
    Location
    Austin, Texas
    Posts
    176
    Items for Sale
    Even better. I'll try that first and get down and dirty with the solvents only if needed. The fewer solvents I expose my black paint to, the better.
  14. #14
    2007 MS3
    Join Date
    Feb 2007
    Location
    Nampa, ID
    Posts
    126
    Items for Sale
    Quote Originally Posted by maczter
    Even better. I'll try that first and get down and dirty with the solvents only if needed. The fewere solvents I expose my black paint to, the better.
  15. #15
    Join Date
    Mar 2007
    Location
    Austin, Texas
    Posts
    176
    Items for Sale
Similar Threads
  1. HID installation
    By TP's02/323 in forum Mazda Protege 5 (Protege5.com)
    Last Post: 05-02-2006, 02:29 PM
  2. Awr side motor install help!
    By Jaysanooch in forum MAZDASPEED Protege (MSProtege.com)
    Last Post: 02-15-2006, 10:44 AM
  3. WTB: American P5 passenger side mirror
    By Cloudland in forum ARCHIVE
    Last Post: 11-10-2004, 01:16 AM
  4. side markers
    By P54DRIDE in forum Protege Appearance
    Last Post: 09-11-2004, 07:51 AM
  5. broken side mirror.. prices?? anyone working in mazda?
    By mofoaka in forum Mazda Protege 5 (Protege5.com)
    Last Post: 04-04-2002, 05:37 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
