Your Best Source for Genuine Mazda Parts!
Page 1 of 2 12 LastLast
Results 1 to 15 of 25
Thread: HOW TO: Change Rear Discs/Pads on Mazda 3
  1. #1
    Registered Member
    Mazda 3 I
    Join Date
    Oct 2005
    Location
    [H]otlanta
    Posts
    26
    edit 26 May 2007: Changed pictures to photobucket so hopefully nobody will have a problem seeing them & they are bigger to boot!
    I have an 06 3i & just went over 40,000 miles last week. The rears discs have been grinding for about a week or so & I figured it was time to get some new pads.
    Took my car to Tires Plus & I was shown that the pads has almost worn down to the rivets & they had also grooved the rotors pretty bad. Tires Plus wanted just about 400 bucks for new rotors & pads + labor.
    Well on a whim, I went back to the Mazda dealer that I purchased my car from. Got the pads rotors & new air filter for 225. Ok, should be a quick in & out job. Little did I know...
    Started off no problem. Loosened the lug nuts & then jacked the passenger rear up. Jack stand in place & everything is a go.
    First part: take the caliper off. There are 4 bolts total. The extreme top & bottom bolts use a hex key. The two inner bolts need are 14mm. Take the extreme top & bottom bolt off & you should be able to work the caliper off. Don't do as I did & take the inner hex bolts off first, as there is really no room becuase of the brake line. I did it but it was nerve wraking. Once you get the two extreme top & bottom bolts off you will have plenty of room to get to the inner bolts.
    This is one of the bolts. All 4 bolts are on the inside, & the normal lefty-loosey & righty-tighty rules still apply, but you will be moving your hands in the opposite direction. edit:Per RickC below all 4 bolts do not have to come off
    This is the piece that is connected by the two inner 14mm bolts
    I don't know the size of this key. I have a set of 12 & this was the 3rd largest.
    Caliper off (use a coat hanger to support it), pads off & old rotor will just come right off. The two little black things are the rubber caps that cover the two outer hex bolts.
    This was the onus for me that started this thread. That caliper has to go back in before you can put on the new pads & or rotors. DO NOT JUST USE A C-CLAMP TO FORCE IT!!! Because this is the rear, the caliper piston is tied into the Emergency hand brake. You have to push & twist, in a clockwise direction at the same time. Ahh lowswr, you say, how the hell I am supposed to do that. Well run, don't walk to Harbor Freight part # 40732-OVGA Caliper Tool Set for Disc Brakes
    In my 40 years, this has got to be one of the best spent 40 bucks I ever did.
    The kit comes with 10 discs of different sizes. Mazda 3 owners don't need any of them. The screw tool has two nibs that will fit perfectly in the two holes on your piston. The plate & the screw tool are separate, but it is easy to figure out how to slide the plate over the handle. Once you get the plate under the outside "teeth" of the caliper, use a 24mm wrench to tighten the plate up. Then just turn the handle (& thus the piston) in clockwise direction. Now you can do this with just some needle nose pliers, but take it from me. Spend the 40 bucks!
    I tried for about 4 hours with needle nose pliers. Took less than 3 minutes to get that piston all the way in with the tool
    I did not know that the brake pads from Mazda came as matched sets. I just grabbed the first two out of the box & spent 90 minutes thinking I had the wrong parts. One with the metal & one without GO TOGHETHER. I put the metal one on the inside, facing the piston.
    New Pads & Rotor installed.
    Now I am sure that for a lot of people this is old hat. I myself have changed front rotors & pads many times, but I had no idea that it was more involved for the rears. However, I hope that some will find this useful.
    That kit will work for many different car manufacturers & from what I understand, if you have anti-lock brakes, you need to twist the piston, in some cases, even for the fronts.
    edit: I realized that the extreme outer bolts use the hex key & the inner bolts are 14mm. Text changed above
    Last edited by lovswr; 04-30-2008 at 07:45 AM. Reason: updated info on 30 April 08
  2. #2
    SELFMADEPRODUCTIONS. roadie's Avatar
    Join Date
    Feb 2007
    Location
    Product of Florida
    Posts
    68
    Thanks for the info.! I learned a bit from it myself!
  3. #3
    Old Fart Rotus8's Avatar
    07 MS3
    Join Date
    Dec 2006
    Location
    Silicon Valley, California
    Posts
    2,338
    I assmue there are supposed to be pictures with this? Anyway, thanks for the writeup, it is useful even without the pictures.
    '63 Buick V8 engined Lotus 7 clone
    '36 Dodge Pickup
    '02 Honda 929, heavily modded
    '07 Mazdaspeed3 Cosmic Blue GT with Nav - MazdaSpeed CAI, SilverStar lights, Modified fog lights, Kyokugen heptagonal wheel nuts, Stebel Nautilus air horns, hardwired Escort 9500i, Auto-dim homelink mirror, Hood gas springs, leather shift boot, ebrake, and console cover, heated exterior mirrors, rear bumper scuff plates. MS Coilovers and camber plates. Hotchkis anti-roll bars. NEW: Magden Gauges on Nav display.
  4. #4
    Registered Member
    Mazda 3 I
    Join Date
    Oct 2005
    Location
    [H]otlanta
    Posts
    26
    Quote Originally Posted by Rotus8
    There are 10 pics. Are you looking from work or some place with firewall restrictions?
  5. #5
    I Alwayz Haz Ava Hottiez Akaveli's Avatar
    Donated: $20
    {2002 Mazda Protege DX}[2004 Acura RSX Type S]
    Join Date
    Jul 2003
    Location
    Petersburg, Va
    Posts
    4,008
    to many red x's
    | F2 CAI | OBX CBE | Draxas Header | Cosworth BSD | BCC | Xenon |TRZ "Dog Bone" Rear Motor Mount | Monzta's Timing Mod | Medieval Lightweight ALT & WP | CPe Standback 2 | TechOne | TWM |
  6. #6
    Join Date
    Feb 2007
    Location
    Product of Florida
    Posts
    68
    I see them all perfectly. Browser problems maybe?
  7. #7
    07 MS3
    Join Date
    Dec 2006
    Location
    Posts
    2,338
    Quote Originally Posted by roadie
    I have tried to view pictures on fapomatic with firefox and IE on two different machines in two different domains. No pictures except the gross ones directly on the site. I suggest you try tinypic.com or photobucket.
  8. #8
    Registered Member Nutari's Avatar
    Donated: $10
    2010 Mazdaspeed3
    Join Date
    Mar 2004
    Location
    Hawaii
    Posts
    3,841
    also see them all
  9. #9
    User is registered MM3Canuck's Avatar
    2007 Mazda3 GT, Galaxy Grey
    Join Date
    Oct 2006
    Location
    Brampton, Canada
    Posts
    592
    Very usefull! Thanks lovswr. I had no clue that the rears need to be pushed & TURNED back in.
    This will be printed and filled for the day I need it!!
    Current MODs: 35%/5% Tint, HID Low-Beams (DDM 6k), HID Fog Lights (DDM 6k), EuroLite High-Beams, SilverStar Front Turning Signal, LEDs: rear turning signal, 3rd brake light (thexenonstore.com), reverse light, license plate light, interior lights (HID white), Smoked 3-LED Side Markers (thexenonstore.com), Smoked Rear Reflectors (by RockBlocker), K&N Typhoon CAI/SRI, 4" Stubby, Pearl Satin Fuel Filler Door, Alum. Mazda3 Door Sills, Silver Brake Calipers, Electronic Rust Inhibitor
  10. #10
    Registered Member
    Mazda 3 I
    Join Date
    Oct 2005
    Location
    [H]otlanta
    Posts
    26
    Quote Originally Posted by MM3Canuck
    No problem.
  11. #11
    Registered Member RichB's Avatar
    2007 Cosmic Blue Mazdaspeed 3 GT
    Join Date
    Feb 2008
    Location
    Denver, CO
    Posts
    1,235
    do the pistons in the front need to be pushed in and rotated?
  12. #12
    Registered Member
    Mazda 3 I
    Join Date
    Oct 2005
    Location
    [H]otlanta
    Posts
    26
    I don't think so on our cars.
  13. #13
    The ghost in the machine major error's Avatar
    07 Mazda 3 GTS HB
    Join Date
    Mar 2007
    Location
    US :: OH :: CLE
    Posts
    536
    ...liberally spray brake-kleen on all metal parts to remove dirt/grease...
    MySpace
    My Trance mixes
    My Pandora Trance
    42 HS Fahrvergzoomin'!
    Aurora Blue '07 Mazda 3 GTS MT hatchback w/ moonroof & Bose package
    Heated mirror swap, K&N Filter & orange footwell LEDs. Hawk HP+ pads, Centric rotors. Kumho Ecsta SPT / Nokian Hakkapeliitta RSi tires.
  14. #14
    Registered Member
    Join Date
    Apr 2008
    Posts
    3
    First I want to thank the author for posting this. I would not have figured it out as easily without it. But I would like to post a couple updates for future "backyard mechanics".
    1. In the section regarding removing the caliper, you don't have to remove all 4 bolts. You only need to remove the "hex head" bolts using the allan wrench. The other part does not need to be removed. After removing the bolts, remove the spring clip and then use two screw drivers on each end of the caliper and you can "walk" the caliper off. Then simply remove the pads. They stay with the part that doesn't need to be removed. That part acts as a hanger for the pads. Pretty cool design actually!
    2. The tool mentioned is necessary to push/screw the piston back into the caliper. BUT, you don't have to buy one. If you have a local AutoZone auto parts store, you can rent one for free. I called mine up, they had two of them, I drove down and got the tool, they charged me $38.41 on my credit card. Said keep it as long as I need it. I brought the tool back in about an hour, and they credited my card back the money. So basically, it's free. You can do this with any tool from AutoZone.
    After doing this job the first time, and knowing what to do, I feel I could put new pads on the rear in about 45 minutes now and that includes removing and reinstalling the wheels.
    Hope this helps,
  15. #15
    Registered Member
    Mazda 3 I
    Join Date
    Oct 2005
    Location
    [H]otlanta
    Posts
    26
    Quote Originally Posted by RickC View Post
    Hope this helps,
    Hey thanks. I have edited my original post with your info.
Similar Threads
  1. ---> *EVERYTHING* ECU fix/comments/thoughts
    By changedman in forum MSP Performance
    Last Post: 05-25-2014, 05:56 PM
  2. Mazda Style: 25 Years of Design
    By mikeyb in forum Off Topic
    Last Post: 12-21-2008, 01:13 AM
  3. Mazda Forums ROTM Polls!! (Oct.)
    By Shane5425 in forum Photos, Videos & Builds
    Last Post: 10-02-2006, 08:07 PM
  4. Replies: 0
    Last Post: 05-01-2006, 07:55 PM
  5. How to: Use 93-96 Mazda MX6 rear strut tower bar for a P5
    By ke20sprinter in forum Mazda Tech & How-To
    Last Post: 01-06-2006, 07:44 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
