Compare auto reliability with reliable results at TrueDelta.com!
Results 1 to 8 of 8
Thread: Protege 5 brake "bleeding"
  1. #1
    Registered Member
    Join Date
    Dec 2006
    Posts
    26
    I have changed rotors and pads all the way around on my 02' Protege 5. However the rear right brake caliper was trashed. I just got the replacement today. From what i know its just a bolt on and hook up the brake line job. Question is how do i properly do this. Biggest question i have is how do i bleed the brakes the correct way. Thanks for and info and help.
  2. #2
    Get You Some! Hughes412's Avatar
    03 Mazda Protege LX
    Join Date
    Sep 2004
    Location
    Austin, TX
    Posts
    3,776
    If you get these it makes it a whole lot easier. You can do them all at once and then you don't have to worry about which one to do first. But if you don't you start at the wheel farthest from the brake booster.
    Quote Originally Posted by Hughes412
    just do yourself a big favor. If you do crake the brake lines you'll have to bleed them (I'm sure you know that). If you do, do yourself a HUGH favor. Spend the extra money and get the self bleaders.
    If you put these on all four corners you can bleed them yourself. If you have a bud with you buy one of the big bottles and do all four at one time and you can flush the system. All though you shouldn't need to do that yet.
  3. #3
    Registered Member
    Join Date
    Dec 2006
    Posts
    26
    How likely is it that Advance or Autozone will have them?
    If not can i just run a rubber tube from the bleeder valve into a bottle of brake fluid. Pump brakes several times and while holding peddle down tighten valve? Should car be running?
  4. #4
    03 Mazda Protege LX
    Join Date
    Sep 2004
    Location
    Austin, TX
    Posts
    3,776
    Very likly. I think I got mine from Vans Auto. A small mom and pop shop.
  5. #5
    Registered Member Reitrof's Avatar
    Donated: $50
    2008 Miata PRHT
    Join Date
    Jan 2003
    Location
    Ottawa ON/Southern US
    Posts
    7,209
    Get someone to sit in the drivers seat and with the bleeder closed pump the brakes 2-3 times and then hold the brake down. Open the bleeder and let the air out. The pedal will sink to the floor. tighten the bleeder.
    Repeat till no air comes out.
    Make sure you keep refilling the master cylinder reservoir.
    HTH.
    Bruce
    2008 Miata Touring PRHT True Red, MazdaSpeed body kit
    RB Intake, RSII Exhaust, RX8 Sways, KW V3 Coilovers, Fiaam horn
    RX7 FD Rims, Kenwood DNX7100, Int Wiper Mod, 3M Bra
  6. #6
    03 Mazda Protege LX
    Join Date
    Sep 2004
    Location
    Austin, TX
    Posts
    3,776
    Quote Originally Posted by a223818
    HTH.
    You don't have to do that if you have these bleeders. All you have to do is crack them alittle and then pump! Just keep the fluid level right.
  7. #7
    '02 Protege 5 '85 300ZX redpr5's Avatar
    2002 Protege5
    Join Date
    Dec 2005
    Posts
    1,655
    HTH.
    i bled the brakes on like 4 different cars in the past 3 days this way, works just fine and its free. no need to get fancy with it. this way works just great
    WTB: DGM Grill F/G!!! (preferably with mesh) PM Me
    Future Mods:
    DG Front Lip, DG Wide Body Kit, DG Type 1 eyelids, OBX Header, Corksport Power Series Exhaust, Katsuro HID Kit and CATZ fog lights
    Completed Mods:
    Fog Light Mod, Megan Racing Lowering Springs (2"), Bomz SRI, 2 12" competition M.A. Audio subs and Power Acoustik LT980 amp, Power Acoustik 1.5 Farad Capacitor, fixed spoiler rattle, 20% tint on front doors, 2.5% tint on rear doors/sail windows, 5% tint on rear window/sunroof, Pioneer DEH-P390MP, Blaupunkt 6.5" door speakers, Power Acoustik NB.1 tweeters, S2K antenna, DIY Red Calipers, PIAA Plasma Ion Yellow Fog Lights
  8. #8
    Hard as woodpecker lips Diehonda's Avatar
    Join Date
    Nov 2005
    Location
    Louisville, Ky
    Posts
    1,616
    You can get some thin clear rubber tubing and fit it over the nipple while you use the manual system above. That way you can have the other end of the tube in a bucket and not make a mess. You will also be able to see bubbles which helps make it easier.
    02 P5 - sold
    07 5 - sold
    07 6 - totaled - damn deer
    10 cx7 GT - sold
    11 6 - hers
    15 6 - mine
Similar Threads
  1. Tripoint Mazdaspeed Protege Brake Rotors
    By FlyinMSP in forum MSP Wheels, Tires, Brakes & Suspension
    Last Post: 12-15-2005, 09:51 AM
  2. Replies: 9
    Last Post: 11-17-2005, 03:56 PM
  3. Sponsorship Policies of Protege Garage
    By Captain KRM P5 in forum Global
    Last Post: 08-20-2005, 11:42 PM
  4. Is wilwood still only big brake kit?
    By p5sundevil in forum Protege Performance
    Last Post: 06-09-2004, 11:00 PM
  5. hand brake light problem
    By mopiko in forum Protege5 Lounge
    Last Post: 01-13-2004, 04:11 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
