VersaTuner - tuning software for Mazdas
Results 1 to 9 of 9
Thread: Where's the best place to port a sub box?
  1. #1
    home's where the heart is musiclikscreams's Avatar
    '02 red MP5
    Join Date
    Jan 2007
    Location
    Sunshine State 954
    Posts
    339
    Question Where's the best place to port a sub box?
    i got 2 subs in 2 seperate enclosures and i wanna port one of em. where do you think the best place to port them is to get the best sound?
  2. #2
    goes to eleven chuyler1's Avatar
    Car Audio & Southern New England Moderator
    2013 CX9
    Join Date
    Mar 2003
    Location
    Live Free or Die
    Posts
    12,333
    Placement of the port is only part of the equation when designing a vented enclosure. In fact, it is the least important part.
    First of all, if you plan to put both subs in your car, they should be the same brand/model and installed in the same type/size enclosure. Mix-matching equipment rarely does you any good. In most cases it just causes more cancelation and less bass.
    Second, in order to successfully increase the amount of bass from a subwoofer by porting, you have to design the box based around the TS parameters of the subwoofer. Ported boxes, as a rule of thumb, are larger than sealed boxes so you can't use your existing box. You will have to design a new one from the ground up.
    The first place to look for a design is the manufacturer's instruction manual or website. If they provide a recommended ported enclosure design you should go with that. If they don't, you'll have to use the TS parameters and a box design program to come up with the optimum design for your subwoofer. The size, shape, port diameter, and port length all play an important role.
    If I have confused you in any way...chances are you are not up for the task. Just throw the subs in the trunk and leave it at that.
  3. #3
    '02 red MP5
    Join Date
    Jan 2007
    Location
    Sunshine State 954
    Posts
    339
    i'm a musician so that all actually makes a lot of sense to me. both subs and enclosures r exactly the same. where can i get the "TS parameters"? and where can i get a box enclosure program?
    thanks for the info. i thought it would be as easy as boaring a big hole in the box. shows what i know haha.
  4. #4
    2013 CX9
    Join Date
    Mar 2003
    Location
    Live Free or Die
    Posts
    12,333
    What is the size, make, and model of the subwoofer?
    WinISD is a good box modeling program.
  5. #5
    '02 red MP5
    Join Date
    Jan 2007
    Location
    Sunshine State 954
    Posts
    339
    they're just some 10" Visonik subs i got @ walmart. they were on sale.
    while we're on the topic... i've got 4 150w 6x9"s in the shelf in the trunk that need an amp. all i got right now is a 1 channel amp i'm usin for my sub. both subs r 300w. what's the best deal to get to power em?
  6. #6
    Pickle Pickle 1sty's Avatar
    Donated: $25
    2006 Toyota Tundra DC
    Join Date
    Aug 2001
    Location
    NH
    Posts
    14,194
    Sell the 6x9s for something worth using. The only thing more useless then 2 rear speakers are 4. If you must keep one set then sell the others to buy something of the matching brand and series for the front.
    The cheapest amp is never worth buying....ever.
    You should be powering the front speakers with an amplifier long before the rears.
    on the ports, keep the port on the baffle
    MECP certified Installer, Infocomm CTS-D certified System Designer
    2009 Nissan Xterra
    2010 Hyundai Genesis Coupe 2.0T
  7. #7
    2013 CX9
    Join Date
    Mar 2003
    Location
    Live Free or Die
    Posts
    12,333
    Anything from Walmart is not worth spending time or money on. If you are looking to spend money, go to a custom audio shop and tell them how much you want to spend. They will get you pointed in the right direction.
  8. #8
    Registered Member Beau M's Avatar
    02 P5
    Join Date
    Apr 2006
    Location
    Burien, WA
    Posts
    237
    If your sitting at a concert, do you sit with your back to the stage? Then why have so many speakers behind you? I rarely ever run rear fill in my rides. If you want the best sound, put your money into front components and an amp for them. Bass is easy, good sound is hard. Oh, and WinISD is great.
  9. #9
    '02 red MP5
    Join Date
    Jan 2007
    Location
    Sunshine State 954
    Posts
    339
    ya i think i'm definately gonna go to a car audio shop. thanks guys
Similar Threads
  1. Jrodhotrod's Audio Install Log - Mazdaspeed 6
    By jrodhotrod in forum Mazda Tech & How-To
    Last Post: 08-30-2007, 08:33 AM
  2. FS: Extremely modified 1993 Probe GT Show Winner in Charlotte, NC area
    By Darren93GT in forum Completed Transactions
    Last Post: 08-12-2006, 06:06 PM
  3. FS: 2 12" Dual subs in Bandpass Box with Sub
    By Blade4804 in forum Completed Transactions
    Last Post: 06-16-2006, 08:31 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
