In Memory of Mazdas247 Member "1338"
Results 1 to 3 of 3
Thread: Tire Rotation Recommendation
  1. #1
    Grand - or - Gangsta G-Papi's Avatar
    '07 Mazda6s Grand Touring Automatic 5D Tropical Island Blue
    Join Date
    Jun 2006
    Location
    Charlottesville, VA
    Posts
    1,105
    The CX-7 Manual (8-28) recommends tire rotation in a semi- X pattern. This brings rear tires to front on the same side, and fronts to rear on opposite sides than their last positions. When done in this fashion, the direction of rotation of the tires that were on the rear is reversed.
    I have NEVER reversed the direction of rotation of a radial tire during the course of rotating the tires.
    Am I missing something, or is this the thing to do?
    A friend of Thunder
  2. #2
    Registered Member
    Join Date
    Aug 2006
    Posts
    18
    Modern radials can be reversed in direction. The stock tires (Goodyears at least) are a-symmetrical, not directional. You obviously wouldn't want to flip a directional tire. However, you can x-rotate modern radials. I work in the tire business and we rotate back to front. Cross rotating on an open differential makes sense because one drive tire will wear faster than the other. However, back to front and you should be fine.
    Just don't expect great mileage out of the OG tires.
    I can't wait to get me some Advans.
  3. #3
    Join Date
    Jun 2006
    Location
    Charlottesville, VA
    Posts
    1,105
    Thanks for the information. I just never did it, and then when I began to run Z rated tires ther were directional, I guess.
Similar Threads
  1. tire recommendation
    By Huascar82 in forum Protege Wheels, Tires, Brakes & Suspension
    Last Post: 07-21-2006, 08:42 AM
  2. lame spare tire bracket
    By uiuc240 in forum Protege5 Lounge
    Last Post: 04-12-2006, 04:46 PM
  3. Replies: 3
    Last Post: 08-16-2005, 01:10 PM
  4. question about tire rotation
    By ND4MSP in forum MSP Wheels, Tires, Brakes & Suspension
    Last Post: 09-04-2004, 06:43 PM
  5. looking for a tire of 195/50/16
    By LapisBlueProteg in forum Protege Wheels, Tires, Brakes & Suspension
    Last Post: 08-04-2003, 12:11 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
