02 Protege ES
- 02 Mazda Protege Es
I am new and I am sure this has been covered but I could use some wisdom here. I have these to error codes p0300 Random / Multiple Cylinder Misfire and p0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
I have replaced my spark plugs with Autolite Platinum. when I got the p0300 error code. the error code went off before I changed the plugs and now they are changed the CEL is still on and sometimes is flashing. what it feels like is that car is bogging and running on maybe two cylinders and has a rough idle to where it almost dies. So I dont think the prob is spark plugs because it was doing it before I changed them and is still doing it.
Oh also my car is the 2.0 and it has 83500 miles on it, I am horrible at doing maintance and usually wait till it gets really bad to fix stuff.
One other thing on side note I changed my front struts and now I have a really bad shake going on pretty much at all speeds. I have taken it to a local tire shop to check the alignment and thats good and checked the balance on the tire and that was good I also had them check to see if the rim was bent and its not. Any ideas?
I really love this car and have never had issues with it and I know that this is standard maint that should have prob been done a while ago.
Thanks in advance
Brad
Thanks in advance
Brad
