Transmission Fluid Change
carter1551
03 Mp5
Is it necessary to change the filter in order to stay within warranty or is it ok if you just change the fluid, any reccomendations for fluid? this is the fluid change that was due at 30,000 i believe.
Do you have a manual or automatic tranny?
If auto then you should change the filter with the fluid.
If manual, there is no filter, just change the fluid. Use Redline MT90
