update, first 5 sets of links will be done soon then off to get sprayed. on the coilover front, i stripped out my whole rear sus in prep for coilover development. my Ksports or going to be turned into ginnies for a custom coilover set up. i'm over-slotting the rear collars for max camber adjustment and adding rear pillow ball mounts + camber plates. the goal is to see how much range i can get out of a custom suspension before working with a sus fabricator on the final build out. expect max height adjustment along with a very static spring rate. goal is to keep the body roll down to a min.
