FS: Extremely modified 1993 Probe GT Show Winner in Charlotte, NC area
Status
Not open for further replies.
Darren93GT
1993 Ford Probe GT
This car has been my pride and joy for over 7 years but due to recent changes in my life it's time to finally say goodbye. It was extremely fun, I learned a ton, and it's going to be hard to have to let it go. Not to gloat or anything, but this is probably one of, if not THE, cleanest '93 Probe GT you'll ever see. The exterior and interior are virtually flawless with an engine bay to match. The car as a whole is completely unique and the recipiant of many awards. Ever since receiving a complete new paint job, the car was garage kept and stored over the winter months, never seeing snow again and very seldomly rain. There isn't a single dent on the car or any major blemishes. I have plenty of people that will tell you this car is practically cosmetically perfect. Just to explain how particular I really was, I had the rotors of my big brakes zinc plated just so that the tiny 1/4" ring that the brake pad doesn't touch wouldn't rust. I have receipts or documentation for nearly every modification on the vehicle listed below which far exceeds the asking price. Along with the list of modifications, the car was extensively and religiously maintained. It has been running with Mobile 1 fully synthetic motor oil ever since I've been in ownership of it, of which it and all other fluids have been changed on a timely basis. The tires on the car have less than 3,000 miles on them with over 90% tread left. New front axles and wheel bearings were installed just weeks ago. It also has new control arms, ball joints, and endlinks; and the struts are less than a year old. The tranny fluid, filter, and gasket were recently changed, along with new spark plugs, spark plug wires, and valve cover gaskets. There is also a brand new bosal header pipe and resonated testpipe installed less than 4 months ago. The carpeting in the car is also new. There isn't a single problem currently with the car, it runs and drives perfectly. Please review the full list of modifications and miscelaneous information below. There is also a ton of photos of the car if you click the link below. It's not going to be easy to let it go, but I hope whomever does end up taking it off my hands attempts to take care it as good as I did.
$8,400 OBO (As is with everything you see)
- For more information or to make an offer, call or email me at:
- (704) 497-6521
- darrenp2@hotmail.com
Pictures:
http://www.bordumb.com/darren/pgt
- Charlotte, NC
Factory Specs:
- 1993 Ford Probe GT
- Electric Current Red
- 2.5L KL03 V6 24v DOHC Engine
- 164 HP @ 6000 RPM
- 156 Ft. lbs @ 4000 RPM
- ATX 4EAT Transmission
Current Mileage:
- 111,000 miles
Performance:
- Hotshot Ceramic Coated Cold Air Intake
- Hotshot Ceramic Coated VAF to Throttle Body Elbow
- J-Spec KL-ZE 65mm Bored Throttle Body
- RawPower Stage 4 Ported and Polished Intake Manifold
- Outlaw Engineering Phenolic Intake Manifold and Throttle Body Spacers
- NOS 5115 Nitrous Dry Kit
- NOS Purge Valve Kit w/ DynoTune Dual Purge
- NOS Bottle Blanket
- DynoTune Nitrous Bottle Heater
- 2.5" Cat-Back Exhaust
- OBX Racing Sports Muffler
- JJM 2.5" Testpipe
- RR-Racing Poly Engine Mount Inserts
- Hayden 404 Front Mount Tranny Cooler
- IAT Mod
- Banjo Bolt Mod
- NGK Spark Plug Wires
- NGK V-Power Spark Plugs
- Walbro 190 lph Fuel Pump
- Optima Red Top Battery
- Custom 4 Gauge Grounding Kit
- Mild Weight Reduction
Braking:
- RR-Racing KVR 12" Two-Piece Front Big Brake Kit
- Front KVR Carbon Fiber Brake Pads
- Rear Brembo Cross-Drilled and Slotted Rotors
- Rear PBR Metal Master Brake Pads
- Goodridge G-Stop Stainless Steel Brake Lines
- Ate Superblue Racing Brake Fluid
Suspension:
- Eibach Pro-Kit Lowering Springs
- KYB GR-2 Gas Struts
- Autopower Street Roll Bar
- 18" x 7.5" Konig Trouble Wheels (21 lbs)
- 10mm Wheel Spacers w/ ARP Studs
- 235/40/18 Kelly Evo Z Tires
- Ractive Rear Strut Tower Bar
Exterior:
- FX Designs Front Combat Chin Spoiler
- FX Designs Rear Combat Skirts
- Ninja Side Skirts
- Wings West Thruster Wing w/ 25" LED
- Electric Current Red w/ Metallic Pearl
- Locks, Antenna, All Emblems, and Washer Nozzles Shaved
- H4 Headlight Conversion
- Fully Functional Sleepy-Eye Mod
- PIAA 910 Series 110w Fog Lamps
- Euro Clear Corners
- 20% Window Tint All Around
- 3rd Brake Light GT Mod
Interior:
- Corbeau Forza Racing Seats
- Corbeau 3-Point Double Release Harnesses
- NR Auto White Faced Gauges
- Carbon Fiber Gauge Bezel
- Lo-Tek Triple A-Pillar Gauge Pod
- Autometer Phantom Electrical N2O Pressure Gauge
- Autometer Phantom Electrical Transmission Temperature Gauge
- Autometer Phantom A/F Ratio Gauge
- Nordskog Digital Mini-Tachometer
- Gray to Black Carpet Conversion
- Aluminum Pedals
- Custom N2O Switch Panel
- Custom Flat Back Seat Eliminator
- Custom Sub and Amp Enclosure
- White Street Glow Neons Lighting Up System Setup
Aesthetics / Misc:
- KL-ZE Mazda Front Valve Cover
- PRD N2O Microswitch Bracket
- PRD Blue Oil Filler Cap
- PRD Zinc Plated Bolts
- PRD Stainless Steel Radiator Hooks
- PRD Stainless Steel Radiator Fan Shroud
- PRD Stainless Steel Fuse Box Cover
- Hose Techniques Super Blue Silicone Hose Kit
- Thermal Flex Blue Silicone Intake Couplings
Audio / Video / Security:
- Pioneer DEH-P7200 Head Unit
- Infinity Kappa 3-Way 6 1/2" Front Speakers
- Infinity Kappa 2-way 6" x 8" Rear Speakers
- Alpine Type-R SWR-1241D 12" Sub
- Alpine V12 Series MRV-T320 Amp
- Lightning Audio Strike 0.5 Farad Capacitor
- KnuKonceptz Wiring Kit
- Viper ESP500 Alarm
- Remote Locks w/ Keyless Entry
Awards / Recognition:
2003:
- Great Lakes Dragaway's Import Wars #3 (06/01/03) - 1st Place Best Domestic
- Schlossmann's Honda City Custom Import Car Show (06/22/03) - 1st Place Best Domestic
- Great Lakes Dragaway's Import Wars #4 (07/13/03) - 1st Place Best Domestic
- Fun Ford Days 2003 (08/10/03) - 1st Place 1970 to Present Ford Vehicle
- 8th Annual Zoo Classic (08/17/03) - 3rd Place Sport Compact Wild All Years
- Mazda Extreme Street 2003 (08/24/03) - 3rd Place Best Domestic
2004:
- Wilde Sport Compact Bash 2004 (06/13/04) - 2nd Place Best Domestic
- Exotic Lowriders 2nd Annual Summer Slam Car Show (08/01/04) - 3rd Place Best Domestic
- Braeger Ford 2nd Annual Car Show (08/28/04) - 1st Place Best Ford
- Braeger Ford 2nd Annual Car Show (08/28/04) - Best Overall Domestic
- Braeger Ford 2nd Annual Car Show (08/28/04) - Best Custom Paint
- Braeger Ford 2nd Annual Car Show (08/28/04) - Best of Show
- Fun Ford Days 2004 (08/29/04) - 1st Place Modified
- Battle of the Imports (09/19/04) - 1st Place Best Sport Compact
2005:
- Tuner Jam (05/08/05) - 1st Place Best Domestic
- Braeger Ford 3rd Annual Car Show (08/06/05) - 1st Place Best Ford
- Battle of the Imports (9/18/05) - 2nd Place Sport Compact
- Don Jacobs Scion 1st Annual Night Visions Show (10/8/05) - 1st Place Best Ford
Sponsors / Partners:
- Dunlop Tires
- Acci-Dent
- Extreme Parts
- Street Graphix
- S3 Magazine
Status
