DTC P2407 [L3]
Diagnostic procedure
DTC P2407 EVAP system leak detection pump sense circuit intermittent
DETECTION
CONDITION
The PCM monitors pump load current (EVAP line pressure), while evaporative leak monitor is operating.
When either of the following is detected 6 times or more successively, the PCM determines EVAP system
leak detection pump heater has a malfunction:
While obtaining the reference current value, the change in pump load current exceeds the specification.
After obtaining the reference current value, the pump load current is kept lower than the maximum pump
load current for more than the specified time.
Diagnostic support note
This is a intermittent monitor (CCM).
MIL illuminates if the PCM detects the above malfunction condition in two consecutive drive cycles or in
one drive cycle while the DTC for the same malfunction has been stored in the PCM.
PENDING CODE is available if the PCM detects the above malfunction condition during the first drive
cycle.
FREEZE FRAME DATA is available.
DTC is stored in PCM memory.
POSSIBLE
CAUSE
EVAP system leak detection pump heater malfunction
PCM malfunction
SparcEE
