Compare auto reliability with reliable results at TrueDelta.com!
Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: Fuses
  1. #1
    Registered Member
    1999 Mazda Protege
    Join Date
    Nov 2005
    Location
    Halifax, Nova Scotia
    Posts
    5
    Question Fuses
    I bought my car used and don't have a listing for the fuses. The cigarette lighter is not working, but I can't find a blown fuse to replace. I checked the fuse panel under the hood and to the right of the steering column. Could someone scan the pages from the owner's manual for me?
    Thanks
    Warren
    email warrens at ns.sympatico.ca
  2. #2
    In Soviet Russia... DiS's Avatar
    Donated: $80!
    2016 Subaru WRX Crystal White Pearl
    Join Date
    Aug 2003
    Location
    NJ
    Posts
    5,735
    not sure if the fuse layout is the same in 99 and 2001+ protege's but Ill go outside right now and check.
    Photography = Passion. Nikon D50.
    My baby is sold but it's in great hands!
    www.HidingPixel.com <-- my photo Portfolio
    My YouTube Channel
    My Flickr Channel
    My Wastegate goes bo.bo.bo.bo.ba.ba.ba.ba.BRRRRRRaBAAAAAAAAAAAAAA
    I like Toitles!
    If common sense would be common, everybody would have it.
  3. #3
    Donated: $80!
    Join Date
    Aug 2003
    Location
    NJ
    Posts
    5,735
    sorry to get back a bit late to ya, but I looked and dont see a specific fuse for a cigg. lighter light. What I did was, I pulled all of the fuses inside the car (one by one) and found the one that hooks up to the cigg. lighter, is coded "H/CLN". Dont ask me what it stands for, lol, because I have no idea, hehe.
    So yea look for H/CLN fuse...its 20amp fuse. Good luck!
  4. #4
    Registered Member
    1999 Mazda Protege
    Join Date
    Nov 2005
    Location
    Posts
    5
    I pulled all the fuses out trying to find one which was blown, but no luck.
    I'll have a look for H/CLN and see what happens.
    Thanks for the help
    Warren
  5. #5
    Donated: $80!
    Join Date
    Aug 2003
    Location
    NJ
    Posts
    5,735
    gotcha. Let me know how it goes
  6. #6
    Registered Member
    Join Date
    Jun 2006
    Posts
    2
    I have the same problem and I have check all the fuses with multimeter both engine fuses box and interior fuses box, they are all ok.
    My cigarette lighter plug is still no power.
    Please anyone help me on this matter.
    Thanks
  7. #7
    Donated: $80!
    Join Date
    Aug 2003
    Location
    NJ
    Posts
    5,735
    Quote Originally Posted by et7223
    Thanks
    what year is your protege? If its 2001+ I can say that you have to look for "H/CLN" fuse. Its inside fuse box inside the car.
  8. #8
    Registered Member
    Join Date
    Jun 2006
    Posts
    2
    Post It's a 2002 but I solved the problem already. Not fuse
    Here what I did, I unplug and took out the Cigarette lighter.
    Behind the lighter plug, there is a wire join from one tap to the center tap melted.
    I take a solid wire about the same gauge and rejoin the center tap to the plug tap and everything back on.
    Quote Originally Posted by DiS
  9. #9
    Donated: $80!
    Join Date
    Aug 2003
    Location
    NJ
    Posts
    5,735
    kewl! Good to see you found the problem
  10. #10
    Registered Member
    1999 Mazda Protege
    Join Date
    Nov 2005
    Location
    Posts
    5
    Finally, seven months later I've gotten around to fixing the problem. The wire behind the outlet had opened. It appears to be a fuse wire which overheated and opened. For now I've put in a copper wire, but may consider some sort of fuse later.
  11. #11
    Registered Member
    Join Date
    Aug 2006
    Posts
    Lighter and Radio Problem
    Thanks for your answer to a question I have been having for a while. But I also have another problem. When I plug anything into the lighter, like my Ipod, the radio goes off, but teh fuse does not blw. As soon as I remove the Ipod adapter the radio goes back on. Does anyone have an idea why this is happening? Coudl it be a bad ground?
    Thanks for your help!
  12. #12
    ms.
    1999 Mazda Protege SE
    Join Date
    Mar 2008
    Location
    Toronto
    Posts
    1
    Help with fuses too..
    Quote Originally Posted by DiS View Post
    I also have a 1999 Mazda Protege and am unsure where the fuse box is actually located. Can anyone tell me where to find it, it would be appreciated greatly. Thanks
  13. #13
    Registered Member
    Join Date
    Jul 2008
    Posts
    1
    Question Cig Lighter mazda Protege 2000
    My Cig Lighter does not work. I want to locate the fuse box, Can someone point out where inside the Hood it sits..?
    Also, if I want to just pull the Cig Lighter out and see if the wiring is burnt just behind it....how do I open it..I do not want to brute force it out and damage something in the process..
    Help appreciated.
  14. #14
    Registered Member
    Join Date
    Jan 2010
    Posts
    1
    92 Mazda Protege Cig Lighter and Radio problem
    I followed the thread and tried all the suggestions, it did not solve my problem. I proceeded to remove the radio and the cig lighter. I unplugged the wires I found 12V on both the Cig and the Radio with both fuses (Radio and Room) intact. I took the Cig housing out to find that there is a small black wire about 1/3 in. in length on the back of the Cig housing it was open. I replaced it and soldered a new one, that solved the Cig. issue now it works. I put the Radio on the bench and took the back off the big heat sink in the back of the radio there is a 10A 2-prong red fuse soldered on the board inside the heat sink, that was blown, I de-soldered it and resoldered a new one put everything back togeher and now both the radio and the sig. are working. Still don't know why the fuse in the fuse box did not blow when my wife left the lights on and drained the battery and when someone helped her by jumping the battery they crossed the jumper cables for a second which caused the problem in the first place.
  15. #15
    '99 Mazda Protege
    1999 Mazda Protege LX 1.6L
    Join Date
    Jan 2010
    Location
    Ohio
    Posts
    1
    Exclamation Answer
    Quote Originally Posted by chakita4u View Post
    There are two fuse boxes, im having the same problem with my cigarette adapter also because i put one of those 12V heaters that plug into a cigarette adapter into my adapter, worked for about 10 mins, then boom i couldnt get my gps, radar, anything to work using my cigarette adapter. I saw something about the (H/CLN) fuse for the 12V, so im going to autozone here in a bit to buy some fuses to see if thats the prob. but as far as your question goes, there is a fuse box inside the driver door right below the steering wheel where the hood pop release is with a cover on it that is labeled "FUSE". and the second one is under the hood directly to the far right of the engine closest to the side of the car, again labeled "FUSE", if your referring to a 99 Protege LX.
Similar Threads
  1. weird fuses in engine fuse box
    By krstofer in forum MS3 Engine & Transmission
    Last Post: 07-18-2004, 12:23 PM
  2. headlights went out, fuses are good
    By 4doors&atrunk in forum Protege5 Lounge
    Last Post: 04-26-2004, 06:17 PM
  3. Popped some fuses in my amp today.
    By Poseur in forum Mazda Tech & How-To
    Last Post: 02-23-2004, 09:29 AM
  4. HELP! new amp popping fuses
    Last Post: 10-29-2003, 12:09 PM
  5. 2 Sets of lbulbs and 4 fuses later.....
    By JcsMP3 in forum Mazda MP3 Lounge
    Last Post: 07-30-2002, 05:21 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
