You know how the cover inside the wheel well for the MS6 is kind of a fabric type material? Can someone check for me to see if that fabric in their rear wheel well is flush up against the body, or is it a little droopy?
I was in an accident with my 3 month old MS6 about a couple months ago. long story short, some dumas rear ended me. dont know why he was looking down instead of at the ROAD! but at least he was honest with me. anyways the problem i have now is that the fabric in the rear wheel well seems a bit loose on one side while the otherside is flush against the body.. but has this bump sticking out (the bump is only on that one side). In both wheel wells, its the side that's closer to the rear of the car that has loose fabric and the bump. i've brought the car into the shop a couple times already, but this time they said the wheel well fabric was suppose to be loose hanging on one side while the other has that protrusion.. "it's how the car is designed". I'm not sure if I believe this. It just seems a bit hard to believe since it just doesn't look right. Also the protrusion is pretty damn close to the wheel. it's about an inch or less to the wheel. I'll see if I can take some pictures for you guys. In the meantime, if you guys could lemme know how your rear wheel well is.. that'd be helpful.
