Ipod Integration w/ LCD text display:
These methods provide an audio input, plus control of an ipod via the stereo controls and display ID3 tag info. on the HU's LCD
AXXESS ipod interface- Full Integration with steering wheel controls, and displays ID3 tag info. on the HU's LCD. Comes in two styles: ipod/auxiliary input, and ipod/XM satellite radio. The ipod/auxiliary version provides a dock connector for the ipod as well as RCA cables for inputing audio from a non-ipod device. The ipod/XM version replaces the auxiliary RCA connector with a XM satellite receiver. The module connects to the stereo through the MD/TAPE slot on the bottom of the HU, charges the ipod, and provides a display of Track/Artist/Playlists on the HU's LCD. The ipod's controls are disabled while connected however the device supports up to 99 playlists on your ipod. Input selection is toggled by pushing the AM/FM button, and then the MD/TAPE (or MEDIA) button. The module is compatible with all Mz3´s which do not have a Clarion HU. Repeat this unit does not currently work with Mazda 3´s with the Clarion HU. Unit is compatible with Navigation, Bose stereo, OEM sirius, other ipod adapters not utilizing the TAPE/MD adapter, and the OEM phatbox. Unit is not compatible with the TAPE/MD modules.
(Note: This method is not compatible with Mazda 3's containing a HU made by Clarion. Clarion HU's are found in most 2007+ Mazda 3's).
DICE w/ Text- Full integration with steering wheel controls, and displays ID3 tag info. on the HU's LCD. Connects to the HU using the sirius/CD changer port, and to the ipod via a dock connector. Charges the ipod while connected. Provides an auxiliary 3.5mm input for other devices. ~$159
(Note: This module is only compatible with HU's that have the "SAT" button).
(Note: I've spoken to the people at DICE, and they have successfully tested this unit in 3's, 6's, and CX-7's. The newest model they've tested on is a 2007 model, so it should be compatible with all year models with the SAT button).
Neo Prolink w/ Text - Full integration with steering wheel controls, and displays ID3 tag info. on the HU's LCD. Ipod is never locked out. Connects to the HU using the sirius/CD changer port, and to the ipod via a dock connector. Charges the ipod while connected. Provides an auxiliary 3.5mm input for other devices. Currently does not work with '08.5 model stereos. ~$179
Mazda ipod adapter '08.5+- Due to a change in harness connectors on the '08 HU Mazda released an ipod module compatible only with '08+ models. You must connect the CAN +/- wires to the LCD harness for text display. This module requires the use of an install kit to connect it to the HU. There are two install kits to choose from. One provides a pass-through for OEM sirius, and the other does not. Both cost the same so I don't see much point in getting the one without just in case you want to add it later.
Ipod Module P/N C29179CFZ ~$113.60
Install w/ sirius P/N C9F4V6029 ~$86.40
Install w/o sirius P/N C9F1V6029 ~$86.40
Ipod Integration:
Audio Link / x car link- Full Integration with steering wheel controls. Provides an option of an ipod dock connector* or a USB plug. Both options come with a 3.5mm line input for non-ipod devices. Connects through the sirius/CD changer jack on the back of the HU. Charges an ipod. Option of playlist mode (controlled by stereo), or direct control via the ipod. ~$125
*Adapters: ipod version have multiple options of adapter cables depending on your input/output needs.Pick the adapter that best meets your needs
Standard connector:
- [li] dock connector, plus 3.5mm audio input[/li]
Optional connectors: (+$5.00. For use with video ipods)
- [li]dock connector, plus RCA video output (No 3.5mm input)[/li]
[li]dock connector, plus RCA video output, plus 3.5mm audio input [/li]
(Note: Song info. is NOT displayed on HU LCD screen).
Aux Mod Advanced- In Beta testing. Will give full ipod integration with steering wheel controls. Provides a 3.5mm line in with connections to a dock connector. Should display ID3 tag information on the HU LCD. Should also integrate with WinAmp. connects through the Tape/MD jack on the bottom of the HU. ~$150
(Note: price and features tentative, unit not yet released)
DICE w/o text- Full ipod integration with steering wheel controls. Connects to ipod with dock connector, to the sirius/CD changer jack on the back of the HU. Charges the ipod. Also gives youa 3.5mm auxiliary audio input for other devices. ~$159
Neo Prolink- Updated version of the Neo Ion. Full ipod integration with steering wheel controls. Connects to ipod with dock connector, and into the sirius/CD changer jack on the back of the HU. Also provides an audio input for other devices (presumably a 3.5mm input). Charges the ipod. ~$199
OEM Mazda ipod adapter (P/N C23679CFZ)- Full integration with steering wheel controls. Connects to ipod with dock connector, and into the sirius/CD changer jack on the back of the HU. Charges the ipod. ipod is disabled while connected to the adapter, and can only be controlled from the stereo controls. ~$119.20
Ipod Integration with External Screens:
These methods provide an external screen, plus control of an ipod via a remote control
Harmon Kardon Drive 'n Play- Provides an external backlit LCD which shows the familiar screen from your ipod. Control of the ipod is through a round knob which functions the same way as your ipod's click wheel. Connects to the ipod through the dock connector, and charges the ipod during use. Has a built in wireless FM transmitter, optional wired FM modulator (see below), and a 3.5mm audio output for hardwire connection to an existing auxiliary input. ~$85 (w/ free shipping from www.amazon.com) Installed Picture #1, Installed Picture #2
(Note: Song info. is NOT displayed on HU LCD screen, all info. is displayed on the external LCD).
Harmon Kardon Drive 'n Play II- Offers the same features as the Drive 'n Play I with some changes. The new version gives you a 3.5" high definition color screen, and both the screen and controller are wireless. The module's "brain" is bluetooth capable for integration with phones or other BT devices, and the new music DJ features allow you to organize your music similarly to that of sirius or regular radio stations. All these improvements come at a premium though. The Gen. II will run you about $400.
**NEW** Alpine eX-10- Similar to the Drive and Play II (see above) the ex-10 provides you with an external screen and controller for your ipod. It connects to any ipod with a dock connector and charges the ipod. All your song information is displayed on the 2.4" full color screen as well as CD cover art (if applicable), and the screen has an option for a blue or red background. The eX-10 connects to the HU via the built in high power FM transmitter, or by direct connection to an existing auxiliary input through it's 3.5mm output. In addition to iPod integration, the eX-10 communicates with your compatible bluetooth cell phone automatically to provide hands-free calling. You hear callers over your car speakers, or through the eX-10's built-in speaker if you're listening to a CD, and they hear you via the included microphone. All of the important caller info shows up on the eX-10's display. If you have music stored on your phone, you can stream that through the eX-10, too. The eX-10 mounts to the dash through an included suction cup, though I imagine other mounting methods will be tried.
At the low price it offers all the benefits of the DnP II without the hefty pricetag. ~$199
Accesories:
Various and asundry adapters, connectors, etc.
Kuda leather console mount- Cleanly mounts to the side of your center console and allows you to mount any device on the end. Conceals all wires and leaves no drillied holes in the car when removed.
ipod cradle w/ video out- Provides a mounting solution for your ipod. Connects to the ipod via the dock connector, and you simply plug the dock connector wire from your integration method into the dock to connect it. There is a 3.5mm video output on the back of the dock. Includes 4 interchangeable iPod holders to perfectly match the fit and style of most iPods including 3G/4G, Video, mini and nano. ~$59.99. Note: This cradle is also sold by Kuda (see Kuda leather console mount)
OEM input switch box (P/N TD1379CFZ)- For 2007 models with the ACI. Allows you to plug the ACI, as well as one of the following: sirius, phatbox, OEM ipod adapter, etc. into the HU via the sirius/CD changer jack. ~$113.60
(Note: One input on the switch box works only with the ACI)
Harmon Kardon Drive 'n Play wired FM modulator- Connects to the Drive 'n Play through the 3.5mm audio output, and then connects to the antenna input on the HU. When in use the exterior antenna is disconnected for improved sound over a wireless FM transmitter. ~$20 (w/ free shipping from www.amazon.com)
(Note: This device is not specific to the Drive 'n Play and will work with any device with a 3.5mm output)
Bookmarks
