So, below is a picture of how I am currently running my bypass valve. Looks terrible but works okay. But I want it to work great otherwise it isn't worth having over the stock bypass valve since as you can see in my sig, I'm not heavily modded. The problem is that the hose clamps loosen up after 30 minutes of driving and although the car still performs, there is some loss in boost pressures as expected with a boost leak! Are there better clamps I can buy or is there a better solution to this problem?? I am running the bypass valve between my stock intake pipe and the hot pipe.
-2007 MS3 True Red
Bookmarks
