Compare auto reliability with reliable results at TrueDelta.com!
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Oil leak around front right tire
  1. #1
    Beat'n up on teh noobs leetpcguy's Avatar
    2001 Miata
    Join Date
    Nov 2005
    Location
    Canton, GA
    Posts
    268
    Just got my oil changed about a week ago, and now i have an oil leak thats aobut 8 inches inside of the front right tire, almost like right below the dipstick. Over the course of about 3 days, it has leaked about a tablespoon of oil. I'm definitly not happy, but i'm sure its not something too bad. I did push it pretty hard last night, but nothing that should have made something catastrophic happen. I've also thought about taking it to a mazda dealer to see if they can fix some other problems, like the poorly attached door panels that i've noticed in my car, as well as the ECU flash. Any comments from MSP Vets will be appreciated.
    Cardomain
    Myspace
    Black Mica MSP #977
    Best MPH to Date:115
    MODS:
    Corksport: Power Series Catless Exhaust, Front and Rear Motor Mount Inserts, Shifter Bushings
    Advanced Auto Parts: 170 degree thermostat, Mobil1 10W30, PureOne 626 filter
    Autometer: Mechanical Boost/Vac Gauge
    SU: Rear Sway Bar Bushings
    Intake: 2002 626 Intake Manifold, FMIC w/HKS BOV, Injen Cold Air Intake
    Protection: Belltronics 870
  2. #2
    2001 Miata
    Join Date
    Nov 2005
    Location
    Canton, GA
    Posts
    268
    bump
  3. #3
    Registered Member 03.5MSP's Avatar
    2003.5 Laser Blue MSP
    Join Date
    Aug 2004
    Location
    Near Philly
    Posts
    1,205
    Thats what I tought with mine, but our oil filter is there and it might have leaked when they changed the oil, as it did with mine. It might me different with your sitiation, but check the filter and make sure its tight and check the drain plug. Wipe off any excess oil around that area and see what happens in a few days. Check your oil level too to make sure ur not loosing more oil than you think.
  4. #4
    Got Boost? jeffmsp's Avatar
    Donated: $10
    2003 MazdaSpeed Protege
    Join Date
    May 2004
    Location
    ON Canada
    Posts
    2,944
    the guy probobly just didnt do a good job cleaning up after he changed the filter and oil got on things like the axle and overtime dripped down. jack up the right side of your car, put a jackstand under and clean the area. check back after a day or two of your normal driving. as long as you are not visibly missing oil on the dipstick(im assuming you have already done this to know you arent running with no oil) and if the oil dripping doest come back then there u go.
    Jeff MSP ~ 2003 MazdaSpeed Protege
  5. #5
    Registered Member orng1's Avatar
    mazdaspeed protege
    Join Date
    Dec 2003
    Location
    Los Angeles
    Posts
    3,257
    I changed oil at a dealer for a while and it surprised me how lazy or sloppy some techs can be. I did that for over a year and I saw about 3-4 motors blow but not from me. Clean up after yourself, always double check the filter and drain plug and check the oil level. Sometimes I would get a guy next to me have a dought in a car he worked on but be to lazy to double check so after a minute I would go and check it cause it bothered me. Most times it was ok but a few times I caught a car without any oil. Long story short always check that there is oil in before you leave and if your in dought about a leak take it back and talk to a manager, the techs get in trouble for doing sloppy work. Good luck, hopefully they just need to wipe it down.
  6. #6
    2001 Miata
    Join Date
    Nov 2005
    Location
    Canton, GA
    Posts
    268
    if it helps any, i just found more oil on my front sway bar, But only a little splatter on the top. thanks for the input
  7. #7
    mazdaspeed protege
    Join Date
    Dec 2003
    Location
    Los Angeles
    Posts
    3,257
    get under the car with a water hose and wash it. Let it dry and check for any leaks.
  8. #8
    Yeah Buddy quatelate's Avatar
    mazda, mazdaspeed protege
    Join Date
    Aug 2004
    Location
    miami, florida
    Posts
    370
    Quote Originally Posted by orng1
    yeah this "master" tech at a dealership i used to work at left a few shop rags in someone's oil pan.... it was halarious to see the look on his face when he took apart the car exlaiming he hadn't done anything wrong and he found the rags in the pan.
    Photobucket - Video and Image Hosting
  9. #9
    2001 Miata
    Join Date
    Nov 2005
    Location
    Canton, GA
    Posts
    268
    pwned lol
  10. #10
    OG, apparently ELEmental59437's Avatar
    2002 P5, 1978 F250
    Join Date
    Aug 2002
    Location
    San Francisco, CA
    Posts
    3,111
    Did you ever solve this problem? Have you checked if it might be the front main seal? Both of my main seals were leaking and I had oil around that area.
  11. #11
    EVO this. Matrix's Avatar
    Silver MSP
    Join Date
    Dec 2003
    Location
    Northern Virginia
    Posts
    1,186
    Exclamation
    Wait....WHAT?!
    Um, I don't think I'd advise that. If there's a leak somewhere the last thing you need to be doing is spraying water all over the engine bay. Just wiping down the area will be fine.
    **2003.5 Silver Mazdaspeed Protege #2048** PCM Reflashed * Injen SRI * GT28RS * CustomMSP SMIC * Hardpipes with MAF Relocation * TurboXS Type-H BOV * Slightly Ported Intake Manifold (VTCS removed) * NGK Spark Plug Wires * Exedy Stage 1 Clutch * JDM Lightweight Flywheel * SteedSpeed Turbo Manifold * Corksport S-Pipe (Jet Hot Coated) * SLS Performance 2.5" J+Mid-pipe with Cat * GReddy SP2 Exhaust * SU Front Motor Mount * AWR Side MM Inserts * Weapon-R Engine Damper * Rear Strut Tower Bar * AXR Rear Sway Bar Brackets * Magnum Cross-Drilled Rotors * SLS Performance Gauge Rings Also: NGK ZFR7F spark plugs * Mobil1 5W/30 oil * Redline MT-90 tranny fluid * MilleniaS PCV * Prosport 52mm Boost & Oil Pressure gauges Planned: H&R/Tein S-Tech Springs * Tokico Struts * Wideband O2 * FMIC * SSAFC * Fidanza flywheel
  12. #12
    2001 Miata
    Join Date
    Nov 2005
    Location
    Canton, GA
    Posts
    268
    well it did stop quite a while ago. I'm coming up on my 60,000 mile tune up, but the dealership wants $1000 for everything. Seems kinda stupid considering most of it is just an inspection. Any comments?
  13. #13
    Join Date
    Aug 2004
    Location
    miami, florida
    Posts
    370
    i believe thats y every1 calls them "stealerships" honestly tho i think alot of they stuff they do do is stuff you should have done just not at the dealership unless ur rich.
  14. #14
    Original Owner dirtysouth_msp's Avatar
    2003.5 Blazing Yellow MSP (Forged)
    Join Date
    Jul 2004
    Location
    Metro Atlanta
    Posts
    1,190
    Quote Originally Posted by leetpcguy
    Don't pay them to do that. Instead, find out exactly what they will be doing to your car (itemized list). If they will not do that, then tell them to f***K themselves (Just kidding no need to be rude, it may work against you later on). If they give you the list, look through and do all of the stuff you feel comfortable doing yourself. Then if there is anything left, price the remaining services with some other reputable shops. You will probably save a lot of money this way.
    Dealership service departments depend on their customers lack of knowledge regarding their cars and autos in general. This is how they get away with charging such ridiculous prices and raping their most loyal customers.
  15. #15
    It is what it is speedprotegewi's Avatar
    05 Eurotrash
    Join Date
    Aug 2005
    Location
    New Berlin ,WI
    Posts
    2,457
    i'll find out today at the locar mazda dealer what is included in a 60k service, unfortunately opinions of dealers differ, all you should need to do is what is in your book
Similar Threads
  1. HOW TO - Turbo Oil Lines
    By Brian MP5T in forum Mazda Tech & How-To
    Last Post: 06-03-2013, 10:12 PM
  2. Mobil 1 Horseshit
    By Matthew in forum Protege Performance
    Last Post: 04-10-2006, 10:58 AM
  3. Plugging leak in oil return
    Last Post: 12-04-2004, 01:09 PM
  4. Found the oil leak
    By Wiggles422 in forum MSP Performance
    Last Post: 10-07-2004, 01:10 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
