Compare auto reliability with reliable results at TrueDelta.com!
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Engine Rebuild Specs
  1. #1
    mx3ownzj00 low_psi's Avatar
    Donated: $10
    ms|slowtege #399
    Join Date
    Feb 2002
    Location
    Ft. Worth, TX
    Posts
    7,112
    I'm trying to gather specs to compile a database for rebuilds. I know xelderex(sp?) has quite a few torque specs already, but bearing tolerances is something that no one has really elaborated on. Turfburn's journal mentions a few, which I assume were the final tolerances.
    I need to snag a manual with OEM specs for comparison to the different tolerances most people are running.
  2. #2
    What "Lifestyle"? kcbhiw's Avatar
    Donated: $5
    Miata / MX-5 Moderator
    64 Valves, 16 Cylinders, 7.2L, 622 HP
    Join Date
    Oct 2002
    Location
    Canton, GA
    Posts
    4,625
    Since you're doing an engine teardown and rebuild, you really should invest in a shop manual. There are a lot of torque and clearance specs that would need to be listed otherwise. It's quite handy to have on hand for other projects as well.
    -Kevin
    2002.5 Protege 5 - The Daily
    1991 Tracer LTS - Turbocharged AWD GRM $2008 Challenger - Follow the build HERE!
    1990 Miata #1 - #80 CSP - '01 1.8L w/VVT Swap, Dedicated Racer
    1990 Miata #2 - #2 Turbocharged Grassroots Motorsports $2007 Challenger - BUILD
  3. #3
    Registered Member igdrasil's Avatar
    12psi Protege5
    Join Date
    Sep 2002
    Location
    San Juan, Puerto Rico
    Posts
    4,081
    not much info on the shop manual for the p5/protege 2.0L.
    The Chilton from the MAZDA 626, Ford Probe and MX6 have everything you need.
    Mods: Oliver Long Rods | CP 8.5:1 Pistons | Microtech LT10S | J&S Knock SafeGuard | HKS Intercooler Meter | Prosport Boost, EGT, OilPress Gauges | MSD RPM Switch w/ shiftlite | Car PC w/ OBDII scan ...etc
  4. #4
    Wagon Power Moonman8's Avatar
    2003 MP5-T
    Join Date
    Jun 2005
    Location
    Albuquerque, NM
    Posts
    747
    You can download the service manual and the parts catalog from this website:
    Link
    Here is another online resource that is identical to the shop manual:
    Link
    DAMN THIS IS AN OLD PICTURE!
  5. #5
    Donated: $10
    ms|slowtege #399
    Join Date
    Feb 2002
    Location
    Ft. Worth, TX
    Posts
    7,112
    I realize having a shop manual is required. This thread was created to gather the specs people have used that don't match OEM specs.
    I'll have to check out that first link when I get home, thanks Moonman. I wasn't aware there was anything out there other than protege5ugly.net
  6. #6
    P1kaChu Haz P4rts 4 yU0 Captain KRM P5's Avatar
    Donated: $15
    2002 BJFW, 2007 BK3P, 1979 SA22C, 2005 BK3P
    Join Date
    Apr 2002
    Location
    Grayslake, IL
    Posts
    20,514
    i have the engine rebuild manual in my hands
  7. #7
    ^o,O^ weltschmerz ^o,O^ TStar's Avatar
    Donated: $5
    2002 EDM 323F
    Join Date
    Jan 2003
    Location
    Germany
    Posts
    774
    where's the link, captain ?
  8. #8
    Donated: $15
    Join Date
    Apr 2002
    Location
    Grayslake, IL
    Posts
    20,514
    Quote Originally Posted by TStar
    its a paper copy, mein freund
  9. #9
    Donated: $5
    2002 EDM 323F
    Join Date
    Jan 2003
    Location
    Germany
    Posts
    774
    i know, but where's the link *hint*
  10. #10
    I am the Stig TurfBurn's Avatar
    '01 Yellow MP3 #1026
    Join Date
    Feb 2004
    Location
    Central Wisconsin
    Posts
    5,348
    there is also a specific engine rebuild manual available that has ALL the specs in it.. but I don't have a link or more info at this point (and I'm really tired so I'm not thinking straight as I'd like)
    Technical blog now available:
    Tuned to Think
    Feel free to provide suggestions for future articles.
  11. #11
    Donated: $10
    ms|slowtege #399
    Join Date
    Feb 2002
    Location
    Ft. Worth, TX
    Posts
    7,112
    Turf, please post your final tolerances/specs you used in your build. Apparently people are missing the point of this thread...
  12. #12
    Join Date
    Feb 2004
    Location
    Central Wisconsin
    Posts
    5,348
    Piston to cylinder clearancing with 10 thou overbore CP pistons: 3.5 thousandths
    Rod to crank bearing clearance (Big End)- Stock
    Crank to Mains clearancing: 1.8-1.9 thousandths
    First Ring Gap: .020-.022"
    Second Ring Gap: .024-.026"
    There you go!
  13. #13
    Donated: $10
    ms|slowtege #399
    Join Date
    Feb 2002
    Location
    Ft. Worth, TX
    Posts
    7,112
    Thank you! Now that the ice has been broken, the others can chime in
  14. #14
    Registered Member blthlt's Avatar
    1995 Eagle Talon TSi
    Join Date
    Aug 2003
    Location
    Charlotte, NC
    Posts
    624
    bump...need more input.
    GT28RS:Perrin FMIC:MPI Piggyback:MPI Dual Extra Injection Setup: Dual 42lb injectors:GHL 3" Turbo Back:Kartboy:AEM:Autometer:Wiseco:K1:FORGED:Fidanz a 7lb. Flywheel:Exedy Stage 1: Justin B P & P
  15. #15
    Dick Ripper iracemine's Avatar
    02 P5, 03 P5, 13 CX5
    Join Date
    Sep 2004
    Location
    behind you
    Posts
    2,914
    Steve I know you are running boost, but why soo much piston ring gap? anyone else run that much?
    You drive fast and get a ticket, I drive fast and get a trophy.
    176.6whp N/A protege5
    http://www.mazdas247.com/forum/showt...N-A-ST2-thread
Similar Threads
  1. Motorcycle engine powered cars
    By mikeyb in forum Off Topic
    Last Post: 02-13-2006, 09:24 PM
  2. New Look Vectra Gets Forceful Engine
    Last Post: 07-15-2005, 09:03 PM
  3. Engine torque specs?
    By seth in forum Protege5 Lounge
    Last Post: 04-28-2005, 07:10 PM
  4. engine cover torque specs.
    By nikshooter in forum Protege5 Lounge
    Last Post: 02-23-2004, 10:17 PM
  5. Mazda Protege FS-DE engine rebuild kit
    By ddogg777 in forum Protege Performance
    Last Post: 02-02-2004, 08:50 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
