Welcome to the James Barone Racing Forum - Upgrade your Mazda with High Quality Parts at Great Prices from JBR!
Results 1 to 4 of 4
Thread: code p0126 odb sensor question
  1. #1
    Registered User
    Donated: $10
    mazda protege 5 silver
    Join Date
    May 2003
    Location
    sd
    Posts
    263
    Items for Sale
    check engine light is on did the odb sensor gave me code P0126 -Insufficient Coolant Temperature for Stable Operation- anyone mechanic out there knows how I can fix this problem any info would help thank you
  2. #2
    Mother Nature's Race Fuel funktownp5's Avatar
    02 Mazda P5 Turbo
    Join Date
    Sep 2003
    Location
    Fort Worth
    Posts
    664
    Items for Sale
    DTC P0126
    DTC P0128 Coolant thermostat stuck to open
    DETECTION
    CONDITION
    DTC P0126
    If ECT signal never exceeds 71°C {160°F} after engine start for specified period, PCM determines that the
    coolant thermostat is stuck open.
    MONITORING CONDITIONS
    — IAT:
    Above -10°C {14°F}
    — Difference between ECT at engine start and minimum IAT:
    Below 6°C {43°F}
    — Vehicle speed
    over 9.5 km/h {5.9 mph}
    DTC P0128
    PCM monitors MAF, IAT, VSS and ECT signals and calculate radiator's heat radiation ratio while following
    monitoring conditions are met. If calculated value exceeds threshold, PCM determines that the coolant
    — ECT at engine start:
    Below 35°C {95°F}
    — IAT:
    Above -10°C {14°F}
    Below 6°C {43°F}
    — Vehicle speed
    above 25 km/h {15 mph} for ATX, 40 km/h {25 mph} for MTX
    Diagnostic support note
    This is a intermittent monitor (THERMOSTAT)
    MIL illuminates if PCM detects the above malfunction condition in two consecutive drive cycles.
    DIAGNOSTIC MONITORING TEST RESULTS is available.
    PENDING CODE is available if PCM detects the above malfunction condition during first drive cycle.
    FREEZE FRAME DATA is available.
    DTC is stored in PCM memory.
    POSSIBLE
    CAUSE
    Coolant thermostat malfunction
    ECT sensor malfunction
    PCM malfunction
  3. #3
    02 Mazda P5 Turbo
    Join Date
    Sep 2003
    Location
    Fort Worth
    Posts
    664
    Items for Sale
    Looks like you themostat is stuck open and proly needs to be replaced, easy fix.
  4. #4
    Registered User
    Donated: $10
    Join Date
    May 2003
    Location
    sd
    Posts
    263
    Items for Sale
    I ain't no mechanic but does it mean just replace the thermostat then? the check engine light came on about 2days ago how long do I have to replace it and is it easy to replace? after replace will the check engine light go away and thanks for replying by the way
    Quote Originally Posted by funktownp5
Similar Threads
  1. CEL code P0031 - bad o2 sensor
    By YellowMP5 in forum Protege Performance
    Last Post: 09-15-2010, 01:35 AM
  2. ODB II Devices Thread - Nology PDA - Beltronics - Autotap - Etc
    By CasopoliS in forum Protege Performance
    Last Post: 10-28-2004, 08:52 AM
  3. CEL code, need some help
    By ^tyrant^ in forum MSP Lounge & Welcome Area
    Last Post: 09-22-2004, 02:26 PM
  4. what's the black mica paint code?
    By mazdaspeed Mike in forum MSP Archives
    Last Post: 03-31-2003, 01:05 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
