hellcat said:It will take almost 3 whole quarts. There are two identical bolts on the tranny, one is a drain hole which at the bottom most part of the tranny, and the other is the hole where you put the fluid in, which is a little farther up on the front (towards the bumper). Fill it until a little drips out of the (fill) hole and you're done.
The gear oil does not have a dipstick, and you cannot overflow it. It is supposed to be filled to the brim. There is even a diagram on the first page of the transmission section of the manual that you posted but have not even looked at. Please don't give false information cause you don't know what you are talking about. KTHX (thumb)mogi said:I would consider that overfilling, something you want to avoid!
There should be a dipstick for testing the fill level. If I remember correctly, mazdas have you shift through all the gears while the car is running, then check the level.
http://www.floptical.net/mazda/ <-- service manual
peepsalot said:The gear oil does not have a dipstick, and you cannot overflow it. It is supposed to be filled to the brim. There is even a diagram on the first page of the transmission section of the manual that you posted but have not even looked at. Please don't give false information cause you don't know what you are talking about. KTHX (thumb)
traitorhound said:yea i think he missed the whole point of the thread and the fact that its a manual tranny. he pretty much described it for an atx though
Th3_Gr33k said:Well you can actually take out the shifter in the car and fill it that way its much much quicker. But thank you, now I wont get too confused. (2thumbs)
Thank you for the helpful information.
Actually it's quite possible. I have done it before on my Hatchi. So I'm sorry... but it's possible.traitorhound said:this is a new one that i ve never heard of. . . taking hte shifter out of the car and filling it that way?
i dont think so man
