Visit TeamMFactory.com for the best Mazda transmission components!
Results 1 to 1 of 1
Thread: Ion Sensing Ignition technology
  1. #1
    _.-._.-._.-._.-._.-._ peepsalot's Avatar
    Donated: $30
    Black 03 MSP
    Join Date
    Nov 2003
    Location
    Austin, TX
    Posts
    4,710
    I have been reading a bit about ion sensing ignition systems, and this stuff is fascinating. I heard about it first from reading on the Megasquirt forums. Apparently there are a few people experimenting with this and working on a solution that would work with megasquirt EMS. Saab is supposedly already using the technology in some of their cars now.
    Here are some links for anyone interested.
    http://www.fs.isy.liu.se/~larer/Projects/main.html
    http://users.tkk.fi/~vvartiov/ion/DIY-Ion-Sensing-2.pdf
    http://users.tkk.fi/~vvartiov/ion/sensor.pdf
    http://www.meaa-mea.com/products/p_ionic.asp
    http://www.mitsubishi-motors.com/cor...003/15E_04.pdf
    http://www.adrenalineresearch.com/iondetectpaper.pdf
    http://www.doublepup.com/BaseQuicki/wiki.cgi?IonSensing
    http://www.vems-group.org/wiki/index.php?page=IonSense
    Basically the spark plug is used as a sort of sensor that can tell at what degree the peak cylinder pressure is produced, and the spark timing can be adjusted on the fly to optimize power and efficiency from this information. It can also be used to detect misfires.
    yep
Similar Threads
  1. HELP: Code P1170
    By livelyjay in forum Protege Performance
    Last Post: 08-18-2008, 10:04 PM
  2. Replies: 0
    Last Post: 10-28-2005, 08:21 AM
  3. MSP ignition map discussion
    By KyRaceFan in forum MSP Performance
    Last Post: 08-23-2004, 02:07 PM
  4. Nology Kit Available
    By soulstylee in forum Protege Performance
    Last Post: 02-14-2004, 12:20 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
