Your Best Source for Genuine Mazda Parts!
Results 1 to 7 of 7
Thread: ABS sensor problems
  1. #1
    Registered Member SmileyBone's Avatar
    Protegé5
    Join Date
    Jul 2005
    Location
    Canada
    Posts
    4
    Question ABS sensor problems
    Hi everyone. I'm new here but I've seen that a couple of you had problems with ABS sensor. I think that 220$ Can are really expensive for something that work that bad. I was wondering, is there a way to bypass it to make the ABS and hand brake light shut down?? I was thinking of removing the LED but is it easy to remove the dashboard?
    Thanks for suggestions
  2. #2
    2003 Protege5 Alumni Action Jackson's Avatar
    Donated: $15
    Join Date
    Apr 2003
    Posts
    1,160
    If you pull out the ABS fuse you will bypass the ABS completely.
    In order to get rid of the ABS warning light and Park Brake Light, I was told by the Mazda mechanic to pull out the bulbs for the warning lights.
    The dealer cannot disable those lights as I was told it was illegal.
    2000 Integra GS Champagne Beige Metallic 5 spd SOLD
    2003 Protege5 Midnight Blue 5 spd RIP
  3. #3
    Registered Member AlbNYPR5's Avatar
    2011 CX-9 Touring
    Join Date
    Nov 2004
    Location
    Albany, NY
    Posts
    171
    Quote Originally Posted by SmileyBone
    Remove the lense over the gague cluster and place black electrical tape over the lights. Problem solved.
  4. #4
    goes to eleven chuyler1's Avatar
    Car Audio & Southern New England Moderator
    2013 CX9
    Join Date
    Mar 2003
    Location
    Live Free or Die
    Posts
    12,236
    If ABS light is on, ABS is already disabled.
    Frankly, $220 is not alot when it comes down to something that could save your life when, for example, a deer jumps out in front of your car.
    ABS has two features that come into play while you brake hard: It keeps your car moving in the direction you steer and it decreases stopping distance. Without ABS, the wheels lock up and you are a sled on a one way track to wherever your car wants to take you.
    In certain conditions such as loose gravel or soft snow ABS can increase stopping distance...however, in these conditions (when you should be driving slow anyway), the ability to maneuver and brake at the same time without pumping the brakes can far out weight the few feet you may have added in stopping distance.
    One of my sensors was replaced under warranty. I'm guessing you are looking for alternatives because your warranty is up. If it is not, take it into the dealer and have them take a look. If it is, take it into your dealer anyway and get it fixed.
    Edit: If you're considering disabling your ABS... read (don't just skim) the following website:
    http://www.abs-education.org/
  5. #5
    Protegé5
    Join Date
    Jul 2005
    Location
    Canada
    Posts
    4
    well it's 220$ + instalation time... And I just changed full set of brakes and tires... and I need to change winter tires too... I don't have enough cash to do it all and the ABS will have to wait. I'll probably fix it before snow, but for the moment, the warning lights are pain in the a**.
    Anyway, thanks for advice chuyler1. The best would be to find a used one..
  6. #6
    2013 CX9
    Join Date
    Mar 2003
    Location
    Live Free or Die
    Posts
    12,236
    Did the brake light coincide with having the brakes done? If so, the mechanic may have disconnected the sensor by accident. If it was the dealer you could claim that they broke it while performing the brake job and they should replace it for free. Its a long shot but worth a shot.
    Also, my dealer will do a free diagnositic and inspection (warranty or not). If yours offers the same service that would determine whether it is actually a bad sensor.
  7. #7
    Protegé5
    Join Date
    Jul 2005
    Location
    Canada
    Posts
    4
    Quote Originally Posted by chuyler1
    Nop. Was there before and thought it might help to change brakes. The rotors were under minimum thickness... The weird thing is that the sensor is working, there is a speed signal coming from it... But the computer read a warning from this same sensor...
Similar Threads
  1. Disabling the ABS DIE DIE DIE!
    By Go Mifune in forum MSP Archives
    Last Post: 11-30-2010, 09:47 PM
  2. curious about ABS
    By Tyger in forum Other Lounge
    Last Post: 08-11-2009, 01:58 AM
  3. Cold Air Intake ABS Harness Issues!!!
    By crossbow in forum Mazda6 Engine & Transmission
    Last Post: 12-03-2004, 03:43 PM
  4. ABS liking to kick in during hard cornering and braking- other folks?
    By rocketspeed in forum MSP Wheels, Tires, Brakes & Suspension
    Last Post: 08-16-2004, 04:11 PM
  5. ABS Feel
    By Snoopy_WG in forum Protege5 Lounge
    Last Post: 12-10-2003, 05:28 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
