Visit TeamMFactory.com for the best Mazda transmission components!
Page 1 of 22 12311 ... LastLast
Results 1 to 15 of 320
Thread: How To: headlight black out for P5!
  1. #1
    trogdor the burninator! xswimordiex's Avatar
    2002 MP5
    Join Date
    Mar 2005
    Location
    so cal
    Posts
    31
    well i dunno how many how to's of this there is but not on this site really, so i thought i'd try one out.
    so you wanna black out your headlights? i did too. first you're gonna need some equipment. all you're gonna need is a 8mm socket, 10mm socket, screwdriver(flat and phillips), an oven, and some paint. i used this kinda paint
    it's Rustoleum hi temp flat black barbeque paint. make sure you get a high temp paint...you dont want those catching fire! dunno if it gets hot enough, but just to be safe.
    ok so to get the headlights off you have to take off the bumper. it's pretty straightforward but there's some tricky parts. unbolt the mudguards on the bottom and the two 10mm bolts attaching it to the undercarriage. then get up under the fender well and unbolt the two 10mm bolts attaching it to the fenders. unscrew the screws along the top of the bumper grill area. now before you try to pull off the bumper make sure you push in the little tabs under the outer part of the headlight, you can push em down with a thin flathead screwdriver. it looks like this close up...
    and it's located right here on the headlight
    so the bumper should come right off after that. don't worry about taking all the fog light and turn light stuff off, you can just rest the bumper right in front of the car like so....
    so after that is off you can start unbolting the headlights. there are three 10mm bolts holding it to the frame. before you pull it off though take off the bumper support brackets from the bumper support beam. otherwise it'll be tough to get the lights out. that thing looks like this...
    make sure you unplug all the lights first! then the headlight should come right out!
    ok next step, getting the light ready for the ez bake oven. the oven heats the urethane or whatever it is that holds the lens on, and makes it easy to take apart.
    you dont need to take too much off just the rubber thing that goes around the low beam and that thing with the tab that holds the bumper on i mentioned earlier. also take out this little screw...
    that screw holds in that side of the lens, so easy to take it off while it's still cool.
    ok it's ready!
    get your oven to 200, shouldn't take long. get a cookie sheet and put a small towel on it, and put your headlight on that. then just plop it in the oven for 10 minutes
    after the 10 minutes is up pull it out (wear gloves! mecanix or the home depot ones i have, cuz the light will be hot!) now to get the light apart just use some flathead screwdrivers and gently pry it loose from the tabs and apart from the housing. be patient here or you'll put some dents in the housing. so once that's completely off, you just have to unscrew the two screws holding the bezel onto the lens.
    now comes the long part. sanding. i used a foam 150 grit pad to get the majority and then a scotch brite to get those fun little spots that are hard to get to.
    so once the lights are all nice and scuffed and smooth, make sure they are clean. then you paint them! i put a few coats. just make sure it's all coated and not to paint too fast or you'll make it run. and let the paint dry a little inbetween coats. then place em in the sun but out of wind for like 30 minutes or so if using the rustoleum
    so once they are dry enough to touch, put em back into the lens and screw em back on. then place them back on the bezel and push em as far as they'll go and put them back into the oven at 200degrees for like 5 minutes. take em out and push the lens all the way on. here's me pushing...
    make sure it's sealed all the way around like this!
    aint that pretty.
    so after that you just put everything back on. dont forget that small screw that holds the edge of the lens on. and make sure you dont have spare parts and then take pictures to show everyone!
    so all in all it took about a total of 4 hours or so cuz i had food halfway through. but i am very pleased with the results. hope you guys enjoy!
    ps. i'm not responsible for anyone blowing up houses, cars, or any bad stuff like that. this is how i did it. you can copy me if you want.
    burninating the city.....burninating the country....trogdorrrrrr!!!!!
  2. #2
    In search for a life. DE31's Avatar
    Pee 2+3
    Join Date
    Feb 2005
    Location
    Somewhere in Cali
    Posts
    1,834
    somebody please move this to the How-To section. i need this in the future thanks!!!
  3. #3
    bacon mountjonas's Avatar
    2013 VRM MS3
    Join Date
    Aug 2002
    Location
    CA
    Posts
    4,233
    Thanks for posting the how-to. The other one kept getting taken away for drama reasons un-known to me.
    Be careful of the clip on the side of the headlight holding the bumper, i snapped one of mine when i did this.
  4. #4
    Pee 2+3
    Join Date
    Feb 2005
    Location
    Somewhere in Cali
    Posts
    1,834
    what they should do is move it to the how-to section then lock it so no one does any of those dramatic stuff....
    Quote Originally Posted by mountjonas
  5. #5
    Career Loser bradicus18's Avatar
    Donated: $10
    2002 Mazda Protege5
    Join Date
    Apr 2005
    Location
    Louisville, KY
    Posts
    1,246
    Whoo hooo! I was just looking for this the other day.
    2002 Mazda Protege5 - Gettin' teh groceries
    2003 Honda Accord LX - Wife's Car
    (redp5) De-snailed as of July 2011.
    Please buy my stuff. (Part 1)
    Please buy my stuff. (Part 2)
  6. #6
    2002 MP5
    Join Date
    Mar 2005
    Location
    so cal
    Posts
    31
    yea i thought i'd post it here so all the p5'ers could see it first. maybe a mod could move it for me, i dont think i can.
  7. #7
    Pee 2+3
    Join Date
    Feb 2005
    Location
    Somewhere in Cali
    Posts
    1,834
    on second thought. leave it here for us P5ers only. heh heh heh.
  8. #8
    2002 MP5
    Join Date
    Mar 2005
    Location
    so cal
    Posts
    31
    he he yea at least our cars can look faster! i noticed more pull in the mid to top end. :rolleyes:
  9. #9
    Suck it!
    Mazda Protege 5
    Join Date
    May 2005
    Location
    Clarksville, Arkansas
    Posts
    82
    Finally! another one this is a gift from GOD!..who drives a MP5 btw
  10. #10
    Donated: $10
    2002 Mazda Protege5
    Join Date
    Apr 2005
    Location
    Louisville, KY
    Posts
    1,246
    (redp5) Yup definately think it will add 5-10 whp. Plus the extra weight of the paint will help w/traction!!!
  11. #11
    Fire Fighter/USAF DeadGeneration's Avatar
    Donated: $20
    '04 RX8
    Join Date
    Apr 2005
    Location
    Laughlin AFB, Texas/Mexico
    Posts
    1,838
    2003 Midnight Blue Protege5 Gone
    2004 Nordic Green RX-8 Gone
    2012 Dark Gray Metallic WRX Current
  12. #12
    Registered Member boo-boo's Avatar
    Join Date
    Apr 2004
    Location
    Halifax, N.S Canada
    Posts
    201
    someday im gonna do that one....... i did the same thing to my fogs.....doesnt look to bad....i think i have a pic somewhere
    as you can see blacked out and still not to bad...imo
    Attached Images Attached Images
    bla bla bla ...mods who needs em
  13. #13
    Where's my damn tool? InFlames's Avatar
    04 S2000
    Join Date
    Apr 2005
    Location
    Hacienda Heights, CA
    Posts
    1,272
    Nice write up.
    www.SOTsyndicate.com
  14. #14
    2002 MP5
    Join Date
    Mar 2005
    Location
    so cal
    Posts
    31
    is this worthy of a how to sticky?
  15. #15
    NEPOC, a way of life. AbsoluteSwed's Avatar
    Protege 5
    Join Date
    Jun 2004
    Posts
    630
    i would say so
    A repsonse to one of my comments. I think its great. found here: http://www.mazdas247.com/forum/showt...2766846&page=2
    your an idiot for being a sweed.."ya see how imature that sounded..now look at your comment and tell me whos an idiot" now i can go on all day and night fighting with you over the internet but that stupid petty shit that pussy ass highschoolers do when someone steals their GF
    (For a really long light it might make sense to shut off the motor completely but by doing so one runs the risk that it won't start up again for some reason or other. )
    wow, just wow
Similar Threads
  1. GI: Projector Headlights.
    By GAspeedProtege in forum Protege Appearance
    Last Post: 12-09-2010, 11:43 AM
  2. headlight problem
    By mopiko in forum Protege5 Lounge
    Last Post: 01-14-2004, 06:49 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
