Upgrade your Mazda with High Quality Parts at Great Prices from James Barone Racing!
Results 1 to 5 of 5
Thread: "Q" size drill bit?!!!?!?!
  1. #1
    _.-._.-._.-._.-._.-._ peepsalot's Avatar
    Donated: $30
    Black 03 MSP
    Join Date
    Nov 2003
    Location
    Austin, TX
    Posts
    4,710
    OK, I need to drill and tap something for 1/8" NPT. I went to a plumbing supply today and got the tap. It didn't come with a matching drill bit though. I asked the guy and he said to just use a drill bit that is closest to it. Well, I got home and looked up what the proper drill bit size would be:
    http://ww2.mne.ksu.edu/classes/ME300...20tapdrill.htm
    Um, OK, what the fuck is "Q", and where can I get one if the plumbing supply store doesn't even carry it? Looks like it's pretty much 1/3", but I don't think any place sells that size either.
    yep
  2. #2
    Wayfarer goldstar's Avatar
    2002 Mazda Protege DX
    Join Date
    Aug 2003
    Location
    Northern New Jersey
    Posts
    483
    The Q size drill bit is from the letter size drill series containing bits from A-Z.
    Q bit diameter = 0.3320" (8.433 mm). Closest fraction size drill bit is 21/64 = 0.3281" (8.334 mm).
    02 DX Millenium Red
    MP3 Strut Tower Bar kit; Cusco Front Lower Arm Tie Bar
    MSP Springs, Struts, Stabilizer Bars, Trailing Links, #3 Engine Mount
    Kartboy Stabilizer Bar Bushings; Nyloil Shifter Bushings; Red Line MT-90 Gear Oil
    MP3 Shifter, Knob and Aluminum Pedal Set
    Suvlights HD Wiring Harness; Osram Night Breaker H4 Bulbs; Exide Edge AGM Battery
    Summer: 5Zigen FN01R-C 16" x 7" Wheels; Yoko S.drive 205/45-16s
    Winter: Enkei OR52 16 x 7" Wheels; Falken Ziex ZE-912 205/45-16s
    Modified OEM Air Intake; Racing Beat Exhaust System; Techna-Fit SS Clutch Line
    Denso SKJ16CR-L11 Extended Tip Spark Plugs; Magnecor wires
    Power Slot Front Brake Rotors; Techna-Fit SS Brake Lines; Hawk HPS Pads
    Red Line Synthetic Engine Oil; C/S Aluminum Oil Cap
    Cyberdyne Digital Gauges: Tach; Ambient Air Temp; Voltmeter
  3. #3
    Donated: $30
    Black 03 MSP
    Join Date
    Nov 2003
    Location
    Austin, TX
    Posts
    4,710
    Where could I get one? Would it be carried at a normal store like home depot?
  4. #4
    Join Date
    Aug 2003
    Location
    Northern New Jersey
    Posts
    483
    I don't believe Home Depot or Sears carries letter size drill bits, only fraction and wire size. A number of online sources carry them. Look up drill bits in Google.
  5. #5
    Donated: $30
    Black 03 MSP
    Join Date
    Nov 2003
    Location
    Austin, TX
    Posts
    4,710
    Crap. I wanted to get this done this weekend. Every time I want to do a simple project, I have to go on a wild goose chase for a single part that no one in the world carries. Why would you have a tap and not a drill bit for the tap? It defies logic. Every place carries brass fittings in NPT sizes, but it's impossible to drill and tap for them.
Similar Threads
  1. Thread size of oil pressure sender ??
    By turboboy in forum Mazda Tech & How-To
    Last Post: 02-21-2003, 06:19 PM
  2. Plus size tire on a P5?
    By ArkosP5 in forum Protege Wheels, Tires, Brakes & Suspension
    Last Post: 01-26-2003, 11:29 AM
  3. Tire size???
    By gjmoreo in forum Protege Wheels, Tires, Brakes & Suspension
    Last Post: 12-31-2002, 12:42 AM
  4. fog light size
    By mp3chic in forum Mazda MP3 Lounge
    Last Post: 10-21-2002, 01:03 PM
  5. what is the max whee/tire size allow..?
    By S4TT in forum Protege Performance
    Last Post: 12-21-2001, 05:33 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
