Visit TeamMFactory.com for the best Mazda transmission components!
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: How-To: DIY Fiberglass Projects
  1. #1
    CasopoliS Design, LLC CasopoliS's Avatar
    Donated: $20
    05 Legacy GT, 06 Accord SE, Civic
    Join Date
    Aug 2004
    Location
    Toledo, OH
    Posts
    2,319
    Below are many links, which describe the fiberglassing process while stepping through some actual projects. Some of these projects are for custom-fit applications, while others are not. Many of them do not apply directly to Mazdas, but I came across new ideas after reading each of them.
    Link 1 - Protege 5 Project (good materials list)
    Link 2 - Sound Domain - Kick Panels and much much more
    Link 3 - Car Domain Kick Panel Project (basically just pics)
    Link 4 - Random Site with many projects (mostly trucks)
    Link 5 - Car Domain - Dash, Glovebox, and Trunk work
    Link 6 - STi Sub enclosure - just pics
    Link 7 - Large PDF from JL Audio, another cool enclosure
    Link 8 - Good writeup with materials list and pictures
    NOTE: You can get large pieces of dense foam, and piece them together with hot glue to form a cube, then you can shape the cube with a utility knife. This will give you a 'mold' that you can now coat with fiberglass. You coat the foam with tape and foil as you see in some of the projects. The difference is, you can cut the foam and pull it out when your piece is fully fiberglassed (assuming your item or enclosure has a hole in it somewhere). Your entire piece will then be made of fiberglass, rather than a wood frame with fiberglass on the outside.
  2. #2
    goes to eleven chuyler1's Avatar
    Car Audio & Southern New England Moderator
    2013 CX9
    Join Date
    Mar 2003
    Location
    Live Free or Die
    Posts
    12,297
    Fiberglass is not suitable for flat surfaces which is why MDF or birch plywood is used for the back and other flat surfaces of a box. When curved it can be very strong but across a flat surface it will flex too much.
  3. #3
    Registered Member GHOSTWHISPER's Avatar
    Join Date
    Apr 2004
    Posts
    2,274
    Nice how tos
  4. #4
    BEETEK! JCell's Avatar
    2011 Accord Coupe
    Join Date
    Mar 2004
    Location
    SFL
    Posts
    7,267
    indeed!!!
    Now rocking a 2011 Accord Coupe 6-6!
  5. #5
    Donated: $20
    Join Date
    Aug 2004
    Location
    Toledo, OH
    Posts
    2,319
    I will be updating this thread once I make my custom SRI air box and subwoofer enclosure. Possibly an amp rack... I dunno. After reading all those I was surprised as to how many people do it the same way. It actually seems pretty easy, but of course... you will have to get used to the process in order to do it well.
  6. #6
    Registered Member JOS3's Avatar
    05 22V mazda3
    Join Date
    Jan 2003
    Location
    willisconsinois
    Posts
    11,014
    i am i the process of building a custom enclosure in my trunk. i am making it completely out of fiberglass because it is very curvy (wood is also heavier).
  7. #7
    555 4EVR cable43's Avatar
    Donated: $35
    ::P5::
    Join Date
    May 2004
    Location
    Philly / MD
    Posts
    1,481
    thanks for all the info.
    do you have any info on fiberglass body work????
  8. #8
    Donated: $20
    Join Date
    Aug 2004
    Location
    Toledo, OH
    Posts
    2,319
    I have seen them use styrofoam, then mold that evenly somehow... then cover that with fiberglass. It is much harder and requires more experience and detail.
  9. #9
    05 22V mazda3
    Join Date
    Jan 2003
    Location
    willisconsinois
    Posts
    11,014
    my progress can be some-what followed in the last few pages of this thread
  10. #10
    Registered Member eljefe305's Avatar
    Mazda, Protege 5, VIVID yellow
    Join Date
    Apr 2004
    Location
    Miami
    Posts
    273
    damn i want to see pictures of that
    Tau Kappa Epsilon - Sigma Alpha Chapter at FIU
    BigBooty - custom cat back, tein s-tech, kart boy short shifter and bushings, 6500k HID's, MAM street sleeper kit, haltech f10x and a shit load of gas being unused
  11. #11
    Mazdaspeed Approved X 3 Rainman's Avatar
    2006 Black Mica MS6 GT + 2007 MS3 (2003.5 Yellow MSP = retired)
    Join Date
    Mar 2004
    Location
    Ottawa
    Posts
    1,881
    Working on a CF upper hardpipe for the stock SMIC now. Two prototypes molds made. One is made of standard flower arrangement foam taped together and shaved smooth. Over this I have laid two layers of fiberglass which I will continue to shape to get a perfectly smooth base over which to lay the CF. The other mold is actually a mild steel hardpipe prototype that had shitty welds (my first attempt at arc welding). I grinded down the welds and JB Welded the pits. I will file this down to a completely smooth surface this weekend. Then I will lay the FG base and the CF over top.
    I am doing a FG/CF composite at this point to test out the process. I have enough CF to do both totally in CF, but CF is rather $$$ so I want to practice the technique first before I commit myself to a completely CF unit.
    I'll post the results when I'm done....hopefully some time next week.
    R
    Current Rides:
    10 WRX STi
    07 Red MS3
    04 Honda CBR600rr
    Previous Rides:
    06 Black MS6 (sad to see it go!)
    03.5 Blazin' Yellow MSP
    00 Protege SE
    91 Yamaha FZR 600
    Other non-Mazda crap
  12. #12
    Mechanically Aptituded 2003protege's Avatar
    Mazda Protege LX
    Join Date
    May 2005
    Location
    Cedar Park (Austin), TX
    Posts
    179
    My first instinct was to do something with a foam, but if you build the foam mold to fit like a glove into a panel, then once you start layering fiberglass onto it, the dimensions of the fiberglass mold immediately exceed those of your available space .
    The first writeup was awesome. I would remove the panel if possible, that would make it easier to remove the fiberglass piece because you could pull on both the fiberglass and plastic, and then use MDF for the flat base.
    Great links. Thanks CasopoliS.
  13. #13
    2013 CX9
    Join Date
    Mar 2003
    Location
    Live Free or Die
    Posts
    12,297
    Most shapes that car audio enthusiasts want to make can be done with a simple wood/mdf frame and stretching fleece. If done correctly, there is very little shaping that needs to be done and a thin layer of bondo will make it smooth as glass.
    Once you have mastered the stretch-n-glass technique you could try experimenting with foam but I wouldn't jump right in.
  14. #14
    2013 CX9
    Join Date
    Mar 2003
    Location
    Live Free or Die
    Posts
    12,297
    I'm thinking about doing custom door panels. (I've had the idea for months but I just don't have the time) Anyway, here are some links that I'm using to cloud my head with ideas:
    http://www.al-eds.com/hotcars/mazda/
    http://www.stollencreations.com/doorpanel.html
    http://www.sounddomain.com/memberpage/216770/2
  15. #15
    Donated: $20
    Join Date
    Aug 2004
    Location
    Toledo, OH
    Posts
    2,319
    Thanks for the extra links!
Similar Threads
  1. Carbon Fiber DIY !!!
    By Andres in forum Protege Appearance
    Last Post: 11-30-2008, 02:25 PM
  2. Mixing fiberglass and MDF... need help.
    By Poseur in forum Mazda Tech & How-To
    Last Post: 04-04-2005, 08:28 PM
  3. fiberglass dash?
    By joka1 in forum Protege Appearance
    Last Post: 06-25-2004, 12:06 PM
  4. Body Kits: JDM fiberglass or Polyurethane?????
    By JDM_familia in forum Protege Appearance
    Last Post: 11-10-2003, 02:16 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
