do you have access to a digital camera to take a couple shots of it?
That is crazy talk...a digital camera??? It isn't like they are found in every single cell phone made in the last ten years.
Ok I couldn't resist. It was 90 degrees yesterday and since my wife did not have to go anywhere I left the hatch open for 6 hours 10:00 to 4:00 PM. in direct sunlight. I am happy to report that the entire body maintained its original form.
Picture uploaded. See 1st post.
Going to need a better angle. Also that won't be a main compression, tensile, nor shear stress point of the hinges and shock mount from the hatch... If anything, it would be under tensile force with an open hatch, but it wouldn't form a dent there without dorming a concave dent in the roof first....
I washed my CX5 today for the first time, I was rather surprised to find the roof give, just with the weight of the sponge!
I've also spent two days under the car painting the chassis/ steel work, tomorrow I'm having a tow bar fitted, so I gave the rear of the car extra attention, I've got to say the chassis is nowhere near as strong as my previous car a Nissan Xtrail, which is probably why the max nose weight (tongue) is only 88kg in the UK, the xtrail was 100kg.
The Mazda is a lightweight car, so a deformed roof were the hatch is connected is entirely possible.
It is flexi! I noticed that with the roof too, I leaned against a door and it buckles in, lean across to lift a wiper before washing and the bonnet flexis an inch,, put your finger about 5 inches up the bonnet from the headlight and move a couple inches outwards and press gentle...like pressing plastic, it is pretty shocking the first time you realise it.
Went to a Polo match on Saturday and did tailgating with the CX-5. The hatch was open for about 5 hours, the temp. was around 90C and the wind was blowing pretty hard. The body has no damage and everything looks like new.
Oww, 90C? That is like 194F. Glad I don't live there!
Ok, if there are dents in the exact spot that the hatch hinges meet the car I would honestly guess that the more likely cause would be that someone, at some time, somehow attempted to extend the hinges beyond their normal range of operation which would have to have been done with the hatch shocks disconnected. Maybe it was at the dealership before the car was purchased and the sun happened to hit it just right the other day so that the OP noticed it for the first time. Maybe the hatch was open and someone backed into a garage and caught it a little too late.
There could be numerous legit explanations, but unless some proof can be given to the contrary, I really don't think that leaving the hatch open for an hour is one of them, especially given that the hatch shocks hold a good deal of the weight when the hatch is open.
it seems plausible that if the gas strut mounts were pulled from someone trying to over extend the gas struts, it could flex the dented area in such a way to where it would bend the sheet metal inward, forming the dent.
This would also explain why there is a similar deformation on the opposite side. Maybe the upwards force to over extend the trunk was done on the driver side?
Any chance someone tried to back it in or out of an opening with the hatch open and caught the hatch on the top edge of the opening?
